need help with the graffiti
  • fantast13
    • Dec 2015
    • 2
    Hey guys,
    I finally bought the car I was dreaming about. But on the bumper and front door there is old graffiti. I do not plan now the whole body repainting. The graffiti is old that why it is not easy to remove. I used the wife’s nail polish and the oven cleaner. Nothing of these has helped. Guys if you aware of any working method, please tell me.
    Thanks for your time
  • audiquattrot
    • May 2008
    • 3836
    try lacquer thinner (testing in a hidden spot of course).
    When I bought my E46 M3 years back, the PO dabbed touch up paint all over the front end of the car and it looked horrid. I used lacquer thinner to remove, and it was safe enough where it kept the OEM paint intact.
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
    • Kershaw
      • 11822
      rubbing alcohol will dissolve a lot of stuff. so will lacquer thinner.
      the trick is to go slowly and work in small areas or you'll really mar the paint.
      AWD > RWD
      • glnr13
        • 1334
        what's the graffiti? paint marker? ink marker? spray paint? solid paint marker? (looks like crayon)
        • ahlem
          • 369
          White polishing compound and a soft old tee shirt. Try an area about the size of a quarter and see how it goes.
          • AndrewBird
            The Mad Scientist
            • 11898
            You can buy graffiti remover in a spray can, but something like acetone will work as well.
            • fantast13
              • Dec 2015
              • 2
              Thanks,
              I haven’t tried it yet. Can I use any lacquer thinner? Will this be good? https://www.mrosupply.com/paint-pain...800-16_krylon/ I want to apply in a small spot under the bumper. I hope it will remove that awful graffiti.
              glnr13, I assume it was the spray paint.
              • AndrewBird
                The Mad Scientist
                • 11898
                Can be bought most places, even walmart. Anywhere that has a hardware department basically.
                • gart
                  • Jul 2012
                  • 295
                  Don't want to use lacquer thinner on single stage paint though.
                  89 325 cabrio in progress m52tub28 swap
                  99 540it
                  86 Volvo 240 wagon
                  99 Cherokee
                  13 Passat
                  • 2mAn
                    Señior Mod
                    • 20705
                    Lets see this graffiti
                    Simon
                    Current Cars:
                    -1966 Lotus Elan
                    -1986 German Car
                    -2006 Volkswagen Jetta TDI
                    Make R3V Great Again -2020
                    • McGyver
                      • 4615
                      I honestly would try this first.
                      Use a rubbing compound to take off the top bit of paint. Then use swirl and scratch remover to get rid of the scratches from the rubbing compound (possibly do this on your whole car to get to good paint). Finally, use a good Cleaning Wax wherever you used the scratch remover. The cleaning wax has a fine grit to help polish up the paint.
                      Be VERY careful with the rubbing compound and because it WILL take off all the paint if you press too hard. Only use a paste rubbing compound by hand. Liquid compounds/waxes can be used with a buffer. I suggest a random orbital buffer to keep from burning off your paint and to prevent swirls.
                      • rcsoundn1
                        • Nov 2012
                        • 3361
                        compound it off, if its just graffitti that will work, and your car prob needs it anyway
                        • ahlem
                          • 369
                          The white stuff is for polishing. The red stuff has more grit for heavy lifting. Start with white.
