How long should a properly running E30 be able to hold a charge without starting?
  • IS300E30
    • Apr 2009
    • 408
    I have a 1987 325ic and its all original.
    How long should a properly running e30 be able to hold a charge without starting?
  • ELVA164
    • 4861
    I mean, I've gone almost a month with no issues. Not sure how much longer would work, but a month shouldn't be too rough. How long is it taking your car to drain the battery? Did you test for parasitic draw?
    • Das Delfin
      • Sep 2014
      • 2293
      I've gone two weeks and been okay. But if you only drive it once a week on the reg, it will kill your battery over time
      • dnguyen1963
        • Nov 2011
        • 2651
        Get a floating charger from HF if you don't drive your car often.
        • e30onBBSs
          • Dec 2014
          • 1347
          You can disconnect your negative terminal as well
          BMW tech
          Umass Amherst
          05 wrx sti
          • McGyver
            • 4636
            There are a lot of factors involved, but I would say that a car driven regularly before being parked with a good battery and without parasitic draw should be able to last a month.
            That being said, I have a couple of car that I barely drive (just move them a a block or two every week or so) and those batteries barely last a month of sitting in the cold without being charged up. If you're going to leave your car parked for a while, I would disconnect the negative terminal to keep the OBC and radio from slowly draining your battery.
              • 34844
              From experience, if its more than 6 weeks get a trickle charger.
              • agent
                Vice Grand Pubaa
                • 7960
                Originally posted by dnguyen1963
                Get a CTEK charger from Amazon if you don't drive your car often.
                Fixed.
                Originally posted by kronus
                • M-technik-3
                  • 18946
                  Depends on few factors, temperature and overall condition of battery, plus charging system and any draw. I have gone over a month. I would leave my car in long term at Frankfurt and the other one at Ramstein. That way I'd have a car on landing.
                  • dnguyen1963
                    • Nov 2011
                    • 2651
                    Originally posted by agent
                    Fixed.
                    $70 vs. $7? I have used HF charger for years without any issue.
                    http://www.harborfreight.com/automat...ger-42292.html
                    w/o 20% Coupon.
                    • agent
                      Vice Grand Pubaa
                      • 7960
                      $70 vs. $7?
                      That's half of what they cost with the Porsche emblem on them. ;)
                        • 34844
                        w/o 20% Coupon.
                        $7 that could potentially burn down your house or ruin a $100 battery. Sorry, no way in hell would I trust that. HF is good for things you'll only use once, or really simple tools that can't fail. The electronic products they sell are complete garbage.
                        I have a Battery Tender Plus for my E30 - it's a bit cheaper than the one agent posted, but it's only 1.25 amps. enough for my use, and it will still charge a battery if it's not completely dead, it just takes a lot longer.
                        • Das Delfin
                          • Sep 2014
                          • 2293
                          Battery maintainers are meant to be left on the whole winter while you don't use your car. I wouldn't really feel safe using one of the $5 HF chargers. Battery Tender brand chargers are really good. Also Schumacher chargers are neat too, usually with more options than BT for a similar price
                          You can get a decent one for like $35
                          • TobyB
                            • 5296
                            Mine sits for months sometimes in the winter.
                            A lot depends on your battery- some have pretty high self- discharge rates.
                            t
