Loud High Pitched Squeal Coming From Behind Dash
  • fakeplstctrees
    • Jun 2013
    • 92
    Hello and Happy New Year my fellow E30 maniacs, hope you're doing well. I am getting a sporadic high pitched squeal/whistle noise coming from behind my dash, and what might be the air vents. It comes and goes with no regularity, and always after the car has been running for a while already. It's happened 3 or 4 times in the 4 months that I've had the car. At first I thought it might have been the stereo, but it wasn't. Then I thought it could have been the bluer l blower fan for the heating and cooling system, but turning the fan off and adjusting the speed did nothing. So far, it's only lasted a few moments before stopping, but I'm afraid it might get worse, and last longer and occur more frequently. Have any of you E30 guys experienced this, or heard of it happening to others, and know what it is? Thank you in advance, I really appreciate any feedback and assistance you can contribute! Chat y'all up soon!
  • UlrichFennec
    • Dec 2014
    • 1268
    Does it intensify under throttle?
    "Leafeon" '92 Lagunengrun 325i Vert (Daily Driver/Project)
    http://www.r3vlimited.com/board/showthread.php?t=366044
    The stickers make it go faster. :nice:
    • fakeplstctrees
      • Jun 2013
      • 92
      Not that I've noticed.
      • ahrensNW
        • Mar 2015
        • 1716
        Have you tried to feed him?
        Hank Ahrens
        1984 Alpine Coupe
        1978 911sc
        • jeffnhiscars
          • Jun 2011
          • 6011
          If it sounds like crickets chirping I now have that problem in BOTH my cars.mthe time caspule started doing it on the drive back from Florida last weekend and my Cabrio started doing it after I upgraded the ac system.
          I don't mind it, but would feed them if that's what it is
          Did BMW offer an insect option ?
          Alice the Time Capsule
          • IceWhite
            • Jan 2015
            • 945
            Check out this thread. Hope it helps.
            1990 325i
            2004 330i Individual 6-speed
            • jeffnhiscars
              • Jun 2011
              • 6011
              That's def a mechanical sound. Mine is def faux crickets
              • mikelat
                • Mar 2012
                • 38
                Been down in Florida
                Probably real crickets
                • Sputnik
                  • Jan 2010
                  • 808
                  Remove and inspect the blower motor for bad bearings or broken fins and check for debris in the cervice where the blower is mounted.
                  White lithium grease and an airgun should be decent temporary fix to the noise
                  • jasonbk
                    • Aug 2011
                    • 555
                    I have this problem..do you know what the issue is?
                    • exhaust
                      • Jun 2015
                      • 411
                      You're serpentine belt is probably dying
