I'm cursed (starter went?)
  • e30onBBSs
    • Dec 2014
    • 1347
    Well before I reveal the e30, I got it home and it was awesome fun driving, seemed to be turn key.
    Well now it won't start. Check the video. I'm going to get it diagnosed by a pro (I have bad car voodoo or something)
    My money is that the starter solenoid works but the starter doesn't for whatever reason. Probably needs a new starter. What do you guys think?
    Sorry, we couldn’t find that page
    BMW tech
    Umass Amherst
    05 wrx sti
  • rturbo 930
    • Dec 2005
    • 2629
    Okay, electronics really isn't my strong suit, but is your battery fully charged?
    • e30onBBSs
      • Dec 2014
      • 1347
      Yes. Sorry for not putting that in. Battery is good, and I even tried to jump it with the mini cooper. Same thing every time.
      Cleaned and reconnected battery terminals, same symptom.
      BMW tech
      Umass Amherst
      05 wrx sti
      • Rob Daman
        • Sep 2014
        • 104
        yea. if you have a multimeter test your battery to see if you have at least 12 volts.
        • e30onBBSs
          • Dec 2014
          • 1347
          Don't have it here but I tried to jump it and it did not do anything better, wish I had it though. Might go get it. I think it's in the back of the other car
          BMW tech
          Umass Amherst
          05 wrx sti
          • AndrewBird
            The Mad Scientist
            • 11898
            Check the ground strap going from the frame rail to the side of the oil pan. Driver side.
            • 330SMG
              • Feb 2007
              • 172
              Had a similar issue. PO had put a kill switch in line to the ignition switch wire and then removed said switch by putting 2 butt connectors in line. Car would randomly not start, even changed a starter first then I looked at a wiring schematic and traced the bad patch job. 20¢ in solder and shrink wrap would have been cheaper than the $150 for the starter and the 8 hours to install it twice.
              1989 Cirrus Blau coupe Racing Dynamics wheels and a Volvo Spoiler.
              • Fsnow
                • May 2015
                • 184
                I would test your battery first. Had a battery crap out in the wife's car, so bad that boosting wouldn't do enough to start it. Really didnt want to start with start function on a battery charger either. Replaced battery, 100% good now.
                1991 318is x 2 .
                • e30onBBSs
                  • Dec 2014
                  • 1347
                  will do.
                  No kill switch in it
                  Good idea. I really should get a voltage number. Weird how the radio plays and windows roll up and everything, but definitely should check it.
                  - Thanks guys. First day of ownership has been fun as hell and unexpectedly bad! Going to have a shop diagnose this one until I get more acquainted, it may not be an m20!
                  BMW tech
                  Umass Amherst
                  05 wrx sti
                  • Das Delfin
                    • Sep 2014
                    • 2293
                    def get your battery tested. If your battery is dead enough, even a jump will not get it started. Take it out and bring it to autozone. If they say it's dead and you need a new one, your next step is to check the alt because a dead alt will kill a battery and could be the root of your problems
                    • Kershaw
                      • 11822
                      Interested in an answer. I have a similar issue. Except I already replaced the starter and it did not fix it at all. I think it's a loose ground somewhere.
                      AWD > RWD
                      • e30onBBSs
                        • Dec 2014
                        • 1347
                        I used a free AAA tow (2.5 miles) to a local shop who will hopefully diagnose it and fix it. The car is so new (and maybe not m20!) so until I get a better grip on it I'm gonna leave it to a pro. Will keep this updated
                        BMW tech
                        Umass Amherst
                        05 wrx sti
                        • rturbo 930
                          • Dec 2005
                          • 2629
                          Originally posted by e30onBBSs
                          and maybe not m20!
                          Erm, how is that? Generally it's pretty obvious if it is or isn't.
                          • e30onBBSs
                            • Dec 2014
                            • 1347
                            haha it's a surprise ;D
                            ofc I would know if it's an m20 or not
                            BMW tech
                            Umass Amherst
                            05 wrx sti
                            • dnguyen1963
                              • Nov 2011
                              • 2651
                              What??? either it is or it is not.
