Oil change recomndations?
  • Rookie88
    • May 2016
    • 54
    Accidentally posted this in FAQ/DIY originally because of my fat fingers on my phone. Anyway, about a week ago I became the lucky owner of a 87' 325es and I'm wanting to do an oil change. I've done some digging as well as asking a friend for recommendations for viscosity to which he said 20w50. (He found it to be the best for our SoCal climate) He also said to not use Shell/Pennzoil. I was wondering if anyone has had bad experiences with Shell or just a reason as to why not to use it. I've also seen the Mahle OC 49 is the go to filter and wanted opinions on that as well.
    Thanks,
    Trevor
  • dmb62
    • Oct 2015
    • 42
    Im running 5w40 in mine that's what majority of people locally were running
    • ELVA164
      • 4861
      There's about 100 threads on this, and you'll never find a consensus. The most important factor is ZDDP; you want to make sure the oil you use has at least 800ppm. 20W-50 is fine in SoCal; so is 15W-40. If it were me, I'd use Mobil 1 15w-50.
      • UlrichFennec
        • Dec 2014
        • 1268
        I usually rock Valvoline 20w50 in the summer and 10w40 in the late fall/winter months and change at around 2500-3000 miles.
        Don't use Pennzoil or Quaker State. Garbage oil.
        I've never had problems with Castrol or Mobil 1, though.
        "Leafeon" '92 Lagunengrun 325i Vert (Daily Driver/Project)
        http://www.r3vlimited.com/board/showthread.php?t=366044
        The stickers make it go faster. :nice:
        • Das Delfin
          • Sep 2014
          • 2293
          I've used Castrol 20w50 in the past but on a recommendation of a friend I'm going to try Valvoline VR1 for its higher zinc content..
          • jeffnhiscars
            • Jun 2011
            • 6011
            VR1 is a racing oil so while it has high zddp is lacks the detergents necessary for extended use. I'm also a fan of M1 15-50 which is not only a quality oil, it has plenty of zddp and is cheap.
            Alice the Time Capsule
            • agent
              Vice Grand Pubaa
              • 7960
              Originally posted by ELVA164
              Mobil 1 15w-50.
              Originally posted by kronus
              • estoguy
                • May 2013
                • 1087
                I use the Castrol Edge 5w50... good zinc package in that one. Goes on sale regularly up here at Canadian Tire - good bang for the buck when it is.
                Been running it about 3 years with no problems. I use the same filter, Mahle OC49 as well.
                Estoguy
                • fresh_TD
                  • Aug 2013
                  • 2457
                  Mobil 1 15w-50
                  Sent from my SAMSUNG-SM-N910A using Tapatalk
                  '91 318i (Alpine) - daily
                  '88 325ix (Zinno) - drive here and there!
                  • Rookie88
                    • May 2016
                    • 54
                    Thanks for the input guys! Looks like Castrol is a safe bet. I also saw a Bosch filter @ AutoZone that fits and think that is gonna be my go to because of availability.
                    • ParksMyCar
                      • Apr 2016
                      • 100
                      Anyone ever go synthetic?
                      • roguetoaster
                        Biggus Tippus
                        • 7830
                        Most of the oils mentioned above are likely synthetics, and there is no reason, other than cost, to not go with synthetic.
                        • ParksMyCar
                          • Apr 2016
                          • 100
                          So would a 20 50 synthetic be totally fine. I really don't care about cost. Just want the best for my engine only has 67,000 on the clock
                          • digger
                            • Nov 2005
                            • 6143
                            a 20W-50 doesn't flow well through the engine at room temp compared to other oils. id look for something 10W-50 or 15W-50 if you can
                            • roguetoaster
                              Biggus Tippus
                              • 7830
                              The 15w-50 Mobil1 is readily available, cheap, and a (supposedly) good oil for M10/20/30/42s.
