What is this pipe.
  • VIe30
    • Jan 2014
    • 25
    What is this pipe.
    So I just snagged another e30 89' 325i and went to fuel up and on my way home the car immediately started to smell like fuel was flowing inside with me. Strong fumes. Got home and pulled out the rear seat and found this pipe (pic attached) was completely corroded. My 84' 325e doesn't have it unless it was replaced but this one does. It seems like a vent for the tank but its steel. Anyone know what it is and how to replace or repair. I was thinking about cutting it out and running a rubber fuel hose.
    Any suggestions would help.
    Thanks
    Sent from my SAMSUNG-SM-G920A using Tapatalk
  • rmdashrf
    • Feb 2014
    • 207
    its a conduit for the fuel vent/expansion tank lines.
    • 101
      • Jul 2011
      • 764
      That pipe contains the three hoses for the fuel tank vapor system. They run from the top of the fuel tank through that pipe and behind the right rear shock absorber and up to the filler neck and fuel expansion tank.
      I had to remove the hoses and cut the rusted section out. I used a piece of plastic swimming pool hose that I got from Lowe's as the replacement.
      Most likely, that protection plate that covers the hoses as they go around the shock absorber is rusted as well. I also found that the larger of the three hoses (the cloth braided one) was deteriorated and leaking on two of my cars.
      Clean everything up, replace the braided hose and short lengths of rubber hose as necessary (use fuel rated hose), grind away the rust and treat the metal, and your fuel smell should go away.
      101
      The E30 collection:
      1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
      1987 325is - Delphin / Black Sport (son #3's)
      1987 325i Convertible - Triple Black
      1989 325iX Coupe - Diamondschwarz / Black Comfort
      1990 325iX Coupe - Sterling Silver / Grey Sport
      1981 Fiat 124 Spider 2000 - Green / Tan
      1998 Volvo V70 GLT - White / Tan
      1998 Volvo S70 T5 manual - White / Taupe
      2001 Ford Windstar - Silver / Grey (parts hauler)
      2006 Lexus GX470 - White / Tan (tow rig)
      • VIe30
        • Jan 2014
        • 25
        Thanks I'll take a look and try that. The metal pipe is completely toast. Barely even a pipe anymore. Rotted straight through the resr seat. When it goes through the rear backrest wall does it exit directly to the wheel well or does it run through the trunk. I didn't pull out the carpet to check as yet.
        • rmdashrf
          • Feb 2014
          • 207
          it runs through the trunk around the base of the rear shock tower.
          • TobyB
            • 5280
            And what's probably stinking are the vapor lines that run through it-
            in particular, there's a steel 'Y' near the filler that rusts through if you look at it...
            t
            • VIe30
              • Jan 2014
              • 25
              t
              Thanks ill check it out also
              • barbierij
                • Sep 2012
                • 1294
                it took me a long time to find it "again" but here is the Y pipe that ruts and leaks.
                OEM and Genuine parts at the best prices. BMW Distribution Piece (Fuel Tank) 16131178752 guaranteed fit and fast shipping
                as seen here:
                found my original post
                FS NY: two Audiobahn A235HC amps and audiobahn 1farad capacitor
                Saab/GM tech2 programming
                My for sale thread
                1990 325iX for sale or part out
                Did you buy something from me? Please leave feedback!
                Originally posted by K20RI_211
                And I have to ask if you make a hobby out of thread-bombing with retarded questions?
                • cory58
                  • 1021
                  Sweet! I thought this part was NLA from BMW. Have you ordered it recently?
                  Cory
                  1992 325i Cabrio
                  1988 320i Touring
                  2000 M5
                  1977 530i
                  2015 328i - Euro Delivery/Performance Center Delivery
                  BMWCCA
                  E30CCA
                  • cory58
                    • 1021
                    On my Touring, the vent tubes come out into the wheel well (not through the trunk) and then run behind the protective plate that routes them behind the shock. I thought the configuration was the same on all body styles, but could be wrong.
                    Cory
                    1992 325i Cabrio
                    1988 320i Touring
                    2000 M5
                    1977 530i
                    BMWCCA
                    E30CCA
                    • cory58
                      • 1021
                      The pipe on my Touring is rusted the same way. How did you seal the opening in the wheel well?
                      Cory
                      1992 325i Cabrio
                      1988 320i Touring
                      2000 M5
                      1977 530i
                      BMWCCA
                      E30CCA
                      • barbierij
                        • Sep 2012
                        • 1294
                        Cory, I bought it about three years ago
                        My for sale thread
                        • cory58
                          • 1021
                          Thanks. I'll give it a try and post results.
                          1992 325i Cabrio
                          1988 320i Touring
                          2000 M5
                          1977 530i
                          BMWCCA
                          E30CCA
                          • VIe30
                            • Jan 2014
                            • 25
                            So I plan to do the pipe this Saturday. Does anyone know the size fuel hoses and length o need because I hate getting into the middle of a repair and having to run to store. Thanks
                            • VIe30
                              • Jan 2014
                              • 25
                              All fixed. That conduit pipe is toast. Have to order the guard plate for the wheel well area. Found out after fixing the threaded hose in the pipe, it ended up being the main fill jose was cracked. Previous owner didnt put the plate back over the fuel level sender section so the smell was coming back into the car. All good now. Thanks for the help.
