s52 e30 W/ NO Power
  • spiDmang
    • 3941
    s52 e30 W/ NO Power
    Hey gang,
    Long story short, I was driving the BMW Centennial meet here in Washington, and my car completely died on me.
    Pulled over, and realized I had NO POWER whatsoever to the car. Flashers dont work, when key is in the ignition on the accessory position, the gauge lights dont come on, and none of the power options are responding.
    Any ideas? From my research, a few members have mentioned the ignition switch, as well as the K5 and K7 relays. What i did notice was that at the battery terminal in the engine bay, one of the power wires were loose and could have potentially grounded out?
    Any ideas or starting points? I have a a good working K5 & K7 relay as well as a ignition switch I could test, so I will do that tonight.
    91' 318iS - S54/6MT Swapped
    08' E90 M3 6MT - Daily
    Originally posted by IronJoe
    Originally posted by 2mAn
  • TobyB
    • 5264
    In the trunk, if the battery terminals are all good (they can corrode internally)
    there is a fusible link in the smaller positive wire itself. It can mechanically fail, and do this.
    Easy to test with a meter- at the front junction block, see if you have power
    on the smaller (10mm nut?) connection.
    hth
    t
    • spiDmang
      • 3941
      hth
      t
      Hi Toby,
      I sent you a PM
      • spiDmang
        • 3941
        UPDATE! Fusible link was the culprit! thanks a ton, Toby :up:
        • 2mAn
          SeƱior Mod
          • 20817
          YAY! this scared me
          Simon
          Current Cars:
          -1966 Lotus Elan
          -1986 German Car
          -2006 Volkswagen Jetta TDI
          Make R3V Great Again -2020
          • spiDmang
            • 3941
            YAY! this scared me
            Scared the shit outta me too. When i was testing the K5 &k7 relays, i thought i fired something within the body harness/fuse box and i was like omgggggg noooooooo
