How to grease the antenna?
  • kencopperwheat
    King of Kegstands
    • 14396
    What do you guys use to grease your power antenna? I use white lithium grease and I have to reapply it once every 3-4 weeks during the wet season. I was thinking about using teflon spray...
    Originally posted by Gruelius
  • Spencer
    • 767
    Mine is stuck half way up. Anyone have any tricks to get some lube in there or is it a lost cause.
    kencopperwheat, any lube that doesn't hold dust should work.
    Spencer
    • LikeCDoos
      • Jan 2004
      • 2522
      i unplugged mine...
      • bimmerphile
        • 3495
        first you have to turn it on so it's up all the way, then use your lube in a smooth up & down motion, gradually getting faster
        • Sean
          • 5793
          Interesting Kris...
          And, I think his idea would work quite well... unfortunately... :x
          - Sean Hayes
          • ///M42 sport
            • 3952
            what kind of lube?
            ________
            Motorcycle tires
            • kencopperwheat
              King of Kegstands
              • 14396
              Originally posted by ///M42 sport
              what kind of lube?
              I use white lithium grease. But I have to take it off and apply new grease every 3-4 weeks.
              • Digitalwave
                is a poseur
                • 6292
                Baby lotion.
                RISING EDGE
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  thanks for the help guys...
                  • randomtask37
                    • 3154
                    Originally posted by LikeCDoos
                    i unplugged mine...
                    wheres the plug, right up in the back?
                    i think im gona do that to mine.
                    98 M3/4/5
                    • kencopperwheat
                      King of Kegstands
                      • 14396
                      i unplugged mine...
                      Just unplug it from the back of the deck. Or unplug the antenna in the trunk.
                      • kencopperwheat
                        King of Kegstands
                        • 14396
                        I'm temped to wire a switch to it.
                        But I lost the little key that allows my CD deck to come out :oops: .
                        • LikeCDoos
                          • Jan 2004
                          • 2522
                          i unplugged mine...
                          just pull back your trunk liner under your antenna and find the power wire that connects to it, then just yank it off. If you listen to the radio then don't do this...i unplugged mine because i don't listen to the radio and my antenna wasn't stock so it rose up like 6ft. It looked real gay.
                          • Sean
                            • 5793
                            The PO of my car wired a circuit breaker switch to the antenna - it's right in the dashboard.
                            It kicks ass. I usually have the antenna off, depends on the clarity of the signal. If I need to hear the radio, I'll put the antenna up. Or, vice versa.
                            Seems like it was pretty simple though. ;)
                            - Sean Hayes
                            • AdamF 88iS
                              • 2051
                              Dont grease it with anything! The reason they get stuck is because people put a bunch of lube onto them, and then every spec of dust that goes on it sticks in the oil and just makes a bunch of sandy oil mud all over the thing.
                              Clean it thouroughly, and once in a while just turn it so the wind blows it and bends it back in the opposite direction.
                              Adam Fogg- '88 M3
                              Common sense- It's the new 'gifted'
