How to grease the antenna?
  • kencopperwheat
    King of Kegstands
    • 14396
    Originally posted by AdamF 88iS
    Dont grease it with anything! The reason they get stuck is because people put a bunch of lube onto them, and then every spec of dust that goes on it sticks in the oil and just makes a bunch of sandy oil mud all over the thing.
    Clean it thouroughly, and once in a while just turn it so the wind blows it and bends it back in the opposite direction.
    Hmmm... I wonder what will take the lithium grease off... might be a while.
    Originally posted by Gruelius
    • OOMPH!
      • 3487
      Originally posted by ///M42 sport
      what kind of lube?
      KY Jelly.....
      seriously, try WD40
      • M42Technik
        • 9781
        Another reason for the E30 M3 antenna switch.
        I can't even get the antenna seal I bought on properly. Bitch just won't go on all the way....
        Reminiscing...
        • grlaneriejr
          • 321
          Guys, why waste time w/ this? I bought a brand new one from Autozone for like 29.99.
          • Spencer
            • 767
            Is the antenna just a generic part?
            Spencer
            • bimmerphile
              • 3495
              you're supposed to put it on with some soapy water
              • M42Technik
                • 9781
                Ah! Thanks for that. I have no idea why I sent you PM on this anyways. :?
                Reminiscing...
                • Rob
                  • 8166
                  i got mine on with no water or anything, just pulled like hell with a pair of pliers from the inside
                  BEERTECH
                  • grlaneriejr
                    • 321
                    Spencer - I'm talking about a whole, replacement power antenna.
                      • 34827
                      I use a fog light switch to turn mine on/off. since I never listen to the radio (not in the last couple years) it's always off. Anyhow, they actually make a product just for power antenna cleaning/lubrication. I just used a paper towel with some WD-40 (to clean mind you not to lubricate!!), cycled the antenna down and then up, polished it, and repeated until it didn't get stuck anymore.
                      • randomtask37
                        • 3154
                        anyone got a write up on how to rig up a switch to turn the antenna on and off (up and down)
                        i have always thought about using the blank button near the rear defrost button but i wouldnt know how.
                        98 M3/4/5
                        • AdamF 88iS
                          • 2051
                          Winnar!
                          Adam Fogg- '88 M3
                          Common sense- It's the new 'gifted'
                          • kencopperwheat
                            King of Kegstands
                            • 14396
                            Are you joking? It's a switch. You connect it inline with the power of the antenna.
                            • bwanac
                              • 3354
                              My antenna only goes up half way,but I never use the radio anyways. sO I am going to shave it once when I get the car painted.
                              • kencopperwheat
                                King of Kegstands
                                • 14396
                                This post has nothing to do with the title of the thred; quit post-whoring.
