How to grease the antenna?
  • randomtask37
    • 3154
    #31
    Originally posted by kencopperwheat
    Originally posted by randomtask37
    anyone got a write up on how to rig up a switch to turn the antenna on and off (up and down)
    i have always thought about using the blank button near the rear defrost button but i wouldnt know how.
    Are you joking? It's a switch. You connect it inline with the power of the antenna.
    no i wasnt joking mr. know it all.
    how am i supposed to know which wire (behind that button) is the antenna wire. or if its not back there, how am i supposed to string it up there.
    is there a wire already attached to that button? how do i connect the 2 wires.
    honestly (as u probobly could tell by now) i dont know really what im doing with stuff like this. i dont wana cut or fry something i need, so instead of giving me a vague, half ass, smart alek remarke. why dont u just keep your mouth shut.
    98 M3/4/5
    • kencopperwheat
      King of Kegstands
      • 14396
      #32
      Behind which button? The antenna power is hardwired to your deck.
      Get a switch, connect a piece of wire to the positive end, connect a piece of wire to the negative end, find the power wire for the antenna, use wire-tap connectors to tap the two wires from the switch to the power wire for the antenna, then cut the power wire of the antenna between the two wire-taps. I'd advise you to shrink wrap the taps too.
      But if you're not too familiar with electronic circuits, you probably should be messing around in there.
      Originally posted by Gruelius
      • bwanac
        • 3354
        #33
        Originally posted by bwanac
        My antenna only goes up half way,but I never use the radio anyways. sO I am going to shave it once when I get the car painted.
        This post has nothing to do with the title of the thred; quit post-whoring.
        Haha, I nailed you, and you nailed me! I was only tring to get my name on every forum as the latest post.
        As for the post, I dont lube my antenna. I tried a little WD-40 when I bought the car to see iof the antenna would go up all the way, but it did not help. Sorry for post-owhoring!
        • randomtask37
          • 3154
          #34
          i have always thought about using the blank button near the rear defrost button.
          thats the button i was talking about
          and thank u for an informative responce. it does sound like more than i wana take on. ill just plug and unplug it whenever i need it.
          98 M3/4/5
            • 34844
            #35
            uhm, have you ever wired up a stereo? seriously, it's not that hard to figure out which wire is what. It's not like there are 10 loose wires back there.. bring a wire from your stereo's antenna-on signal to one terminal of the switch, and the antenna wire to the other terminal. Just use female crimp terminals (I think 16 gauge terminals plug right onto a foglight switch). it's not rocket science!
            on my car, the antenna power wire was white (as far as I can remember).
            • kencopperwheat
              King of Kegstands
              • 14396
              #36
              If you're referring to the black button, it's a circuit breaker for your power windows.
              • mikey
                • Mar 2004
                • 208
                #37
                i've still got a little cleaning wipe for the anntenna that came in a bmw brochure on how to keep your car clean..15 years old now...
                My transaction feedback thread(s):
                http://www.r3vlimited.com/board/showthread.php?t=292029 :up:
                http://www.r3vlimited.com/board/showthread.php?t=329392 :up:
