MarkD chip install anxiety!
  • silversleeper
    • Mar 2005
    • 2032
    So, I got my car, and it has a 173 ECU in it... but the 19lbs injectors are in my other E30. The E30 I want to install the chip in still has the 14lbs stockers. What could I expect to happen if I were to install the chip without the injectors? Would I even notice a gain, seeing that the injectors will be maxed out? What could go wrong?
    I wont have time to install the injectors till this weekend, but a chip install is a matter of minutes. SO, enlighten me before I do something stupid.
    Claus Luthe is my hero.
  • parkerbink
    • Jun 2004
    • 10138
    I may be wrong but seems to me the worst that will happen is fuel starvation at full throttle which will only cause a seconds loss of power. Just don't drive at full throttle and I'd think it will be ok for a few days.
    • PeaveyBassist
      • Sep 2004
      • 3511
      Stock 14lb injectors are good up to 200hp or so. The Alpina B2.7 uses stock 14lb injectors.
      Will
      RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
      Welcome e30 (brilliantrot '90 325is) 12/23/06
      DaveCN = Old Man
      My signature picture was taken by ME! Not by anyone else!
      If people keep quoting me in their sig, I'm going to burn this motherfucker down.
        • 34844
        Will
        they probably aren't using the stock FPR though..
        also, that's 200hp at 100% duty cycle.. not a good thing!
        • PeaveyBassist
          • Sep 2004
          • 3511
          Just sayin ;) You can use stock injectors. It shouldnt run lean because of them.
          Will
          DaveCN = Old Man
          • Mystikal
            Wheel Fitment Expert
            • 9602
            Will
            Lies.
            I was on the dyno with MarkD when we discovered the limits of the stock injectors, and the reason he made two different copies afterwards. They maxed out at everything above 3500rpm, rather badly. Still relatively safe (the AFR was somewhere around 14-15), but I still wouldn't do it again.
