Mystery Goblin Killed my Engine
  • jeffnhiscars
    • Jun 2011
    • 6011
    So I get to a rd light and my gauges go dead. No hiccup, no misses...the car just stopped as I sat at a light. I tried to restart it and no crank, the needles don't move, the hvac blower and check panel are not working. I do have windows, radio, turn signals etc.
    While waiting for the tow truck I check with 2 of my experts who both think ignition switch. When I get back I pull thenswotch, checkmeach wire for continuity then check for proper operation. The switch seems fine so I reinstall it.
    I put an alligator clip on the solenoid wire at the starter and connect the other end to my VOM inside the car, turn the ignition and nothing. I disconnect the black solenoid wire on the engine side of c200 on the steering column and connect my jumper to here so I have now bypassed the c200 to starter wire.
    Starts right up, runs perfectly, tach runs for 3 seconds then stops but the engine keeps going like the good ole days. The check panel now lights
    I check all the fuses, switch around the orange relays/unloaders, no change but I do note that my right low beam is out. I swap bulbs and fuses and nonchange so it's also the low beam circuit
    I'll dive back in tomorrow but thought I'd share this. Educated guesses welcome
    Alice the Time Capsule
  • superj
    • Feb 2006
    • 397
    bad wire in c200, or bad connection in c200?
    • jeffnhiscars
      • Jun 2011
      • 6011
      Keep in mind multiple things werent working
      I actually fixed this but I'm interested in the opinions before I share
      • Das Delfin
        • Sep 2014
        • 2293
        my guess would be something silly like an electrical connection such as a bad engine ground
        • TobyB
          • 5297
          or fusible link in trunk. Monkey got bored, fucked with it.
          t
          • squidmaster
            • Aug 2011
            • 2666
            definitely going with shorted connection but it's hard to pinpoint. Curious as to the issue turned out to be
            • Cephas
              • Apr 2012
              • 878
              Sounds like a bad ground? Probably the one by your feet on the drivers side.
              • noid
                • 1537
                DME Relay = crank but, no start
                Engine ground on drivers side from oil pan to body = no crank, but bump starting will work if its a manual.
                To rule out the engine ground: take some jumper cables and attach one end to your oil drain plug and the other end to your steering rack. Then try starting the car.
                Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
                Your resource to tools and tips: www.rtstools.com
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  Let me clarify a couple of things. Of all the checking I did in the OP, I missed something and rather than say I fixed it I'm going to say I got it running and everything works. I'm not certain yet that it's fixed although I drove around Tampa yesterday without issue
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    Bypassing C200 did allow it to start but that could be from a bad component
                    This was the first thought I had.
                    t
                    It's a cabrio so nothing in the trunk. I also think a fusible link would kill the whole car rather than just parts of it. I'm not aware of how many there might be but I think just one.
                    Agree
                    IVe driven 1000miles or so since my dash swap so one possibility was that I pinched or damaged something that decided to go wrong st that very moment so in addition to removing the ignition switch I did poke around above the pedals quite a bit. Didn't find anything.
                    Good point. This was no crank no start but I'll recheck the engine to chassis grounds.
                    • squidmaster
                      • Aug 2011
                      • 2666
                      Okay actually since reading the mysterious things you just posted I'm going with loose battery terminal haha
                      Sent from my Robin using Tapatalk
                      • jeffnhiscars
                        • Jun 2011
                        • 6011
                        Jesse I'm hurt.....lol
                        Remember I had working windows, radio, alt light etc so I had juice
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          I double checked the fuses with a VOM and #10 was bad. After replacing it everything is perfect. This pretty much rules out grounds as a cause.
                          I can't say if it was a mechanical failure from fatigue or something that caused it to blow which could happen again. I'm driving back o Charlotte today with some spare fuses and just hope I don't go through them.
                          • squidmaster
                            • Aug 2011
                            • 2666
                            Hahaha hey! When the temperature changes like this sometimes the metals expanding and shrinking can cause the terminals to go loose. But I forgot about the windows.
                            So tellme already! I want to know! Hah
                            • jeffnhiscars
                              • Jun 2011
                              • 6011
                              I told you. It was fuse 10 and I drove 600 miles today and car was flawless.
