Hey Everyone,
1990 325i m30 swap.
Im having a no fuel & no spark issue.
Also not getting now power on DME pin 37 & when i ground pin 36 the DME relay clicks. Jim Levie said if it does that then DME is bad. Also, one day i hooked the battery terminals reversed and blew the in-line fuse , could that have fried the DME? Should i just gohead and replace?
btw
NEW:
CPS
Fuel relay
DME relay
Spark plugs & wires
Distributor
In-Line fuse
coil
Any suggestion?
Thanks!
1990 325i m30 swap.
btw
NEW:
CPS
Fuel relay
DME relay
Spark plugs & wires
Distributor
In-Line fuse
coil
Any suggestion?
Thanks!
