Performance Chip
  • deeclue
    • Jul 2015
    • 92
    Performance Chip
    Hello, so I'm in the process of doing a little work on my 89 ix because it just failed emissions testing. I'm replacing the cat/muffler and have cleaned out the MAF/ICV. My next step was investigating the possibility that this car was chipped by the previous owner. I had my suspicions but never knew for sure.
    After pulling the computer out and looking I could kick myself for not doing this long ago because it took like 5 mins. Yes indeed it has had a Dinan D900-2532 this whole time. I couldn't fine a lot of specifics about this chip, but I assume it requires premium, which I have not consistently run. (whoops) Anyway I want to swap it for a chip that can just run on regular octane and I'm curious if anyone has any recommendations?
    The main one I've found so far is from Sssquid, but I wanted to make sure there weren't other good options to choose from. I'm definitely keeping the Dinan around - you know, just in case - but as a daily driver I'd rather be able to run regular.
    Thanks!
  • AndrewBird
    The Mad Scientist
    • 11898
    Why do you not want to run premium? It's only $3.20 more per tank. The chip likely makes you get better gas mileage too.
    • deeclue
      • Jul 2015
      • 92
      Haha, yeah I had a feeling removing a performance chip would be like sacrilege to some people on here. I'm just trying to take it back to stock, I'm going to keep the chip around in case I change my mind down the line.
      • ForcedFirebird
        • Feb 2007
        • 8300
        Don't need premium for Dinan (and AA) chips. I have read the file and they only added a few degrees of timing across the board and raised the rev limiter (to where the m20 makes no power).
        If you want a good chip that has a real tune on it, go with MarkD or SSSquid (both forum sponsors).
        john@m20guru.com
        Links:
        • jeffnhiscars
          • Jun 2011
          • 6010
          Not to mention that many higher octane recommendations are cya. For anything modest try using regular and if you don't get detonation you're good to go
          Alice the Time Capsule
          • deeclue
            • Jul 2015
            • 92
            Thanks for all the info! Yeah I'll probably get a MarkD or SSSquid chip, and see if it runs between.
            • sampayne
              • Apr 2014
              • 396
              +1 for SSSquid
              Originally posted by 2mAn
              The BMW V6 is the best
              • Das Delfin
                • Sep 2014
                • 2293
                I put a MarkD chip in my car last year and at the risk of sounding like a cliche, it really woke the car up.. of course runs on premium fuel
                • e30rapidic
                  • 2167
                  Hey, you're not alone. I just did the same thing for my S50. ;)
                  '87 325ic, powered by S50.
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    Chips work, but often are "over-advertised". A dyno tune on a stock engine is usually good for anywhere from 5-10whp.
                    john@m20guru.com
                    Links:
                    • deeclue
                      • Jul 2015
                      • 92
                      Well I bought and installed a regular octane sssquid chip, now I just need to get the rest of the car back together to test it out. I'm curious if I'm going to really notice much of a difference. I'll report back.
                      • bmwman91
                        • Oct 2004
                        • 3128
                        +1 on SSSquid. I have been working with him on a custom project and he definitely does more than just a couple of small tweaks to the WOT maps. He seems to go through everything from idle to part-throttle to WOT to improve power and driveability.
                        Transaction Feedback: LINK
                        • deeclue
                          • Jul 2015
                          • 92
                          Day one of finally driving my car with the new chip, and it runs soooo much better than it did before. Much more quiet and smooth. I can definitely feel that I don't have quite as much punch when accelerating as I used to, but I expected that because I went with the regular octane stage 1 chip. But the acceleration also feels smoother and more consistent. All around very satisfied with the SSSquid chip - highly recommend if anyone is on the fence.
