e-brake shoe thickness
  • ecsk
    • Nov 2011
    • 106
    What is the min. thickness of the parking brake shoe before it need replace ?
    Bentley manual does not have the spec.
    I tried to adjust e-brake with no luck, followed most of the procedure available on the web already, I suspect the shoe lining is too thin, it has about 2 to 3 mm thick.
  • uturn
    • Dec 2010
    • 998
    You're doing something wrong because that bad boy can get up metal to metal contact.
    • jeffnhiscars
      • Jun 2011
      • 6010
      If there's not enough adjustment at the star nut (in the drum) then back them off a bit adjust the 2 nuts under the brake handle.
      Alice the Time Capsule
