early model in tank pump options
  • dougie30
    • Apr 2012
    • 1708
    My in tank pump has been dead sense i bought the car and the in line pump has been doing all the work. now i would like to replaced the in tank pump so the system will work properly.
    so far the options iv found from searching are- walbro255 (not really interested in removing the inline pump), oem in tank at the price of 300$, or a shit airtex pump that i have heard are garbage.
    so what there is no in between? anyone find a decent oem replacement for under 150$?
    M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
  • reelizmpro
    • 9552
    Search for the GM Vega pump.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • TobyB
      • 5280
      I've never found an in- between, either. Eventually, I gave up and put the later in- tank pump in.
      now I kinda want to try this- one on each side in the tank, feeding a surge tank somewhere else.
      bkuz race car.
      t
      • dougie30
        • Apr 2012
        • 1708
        bkuz race car.
        t
        Will this work as a direct replacement? I want to keep my inline pump
        Sent from my MotoG3 using Tapatalk
          I have set up a dual pump system on a race car. I used a low pressure pump on the left side feeding fuel to the high pressure pump pot on the left side. I once ran the tank down ~2 gallons in a race with no adverse affects. One side of the level sensor in the lift pump is grounded. So to get the gauge to work I had to insulate the lift pump.
          • reelizmpro
            • 9552
            Yes, more or less. It'll work like the stock transfer pump feeding the main external pump, just a lot cheaper.
            On my M3, I deleted both pumps and installed a Walbro intank pump for simplicity. Works great and the car runs well. The original pumps were almost 30 years old anyway.
            88 M3 - LACHSSILBER
            • dougie30
              • Apr 2012
              • 1708
              Nice I'm definitely going to go this route, for 30$ you can't lose
