Gas leak but from where?
  • parkerbink
    • Jun 2004
    • 10138
    I picked up the passenger side of my cabrio and gas leaked out.
    This is on the driver side above the gas tank.
  • jeffnhiscars
    • Jun 2011
    • 6011
    There's gasket on the fuel,pump flange
    Alice the Time Capsule
    • M-technik-3
      • 18946
      Or the seam is rusted, you did not say how much fuel is approximately in the tank. DUH RIF LOL yeah seal on the pump. Gas doesn't defy gravity.
      • uturn
        • Dec 2010
        • 1005
        Cracked hose or bad seal. AutohausAZ was selling some Meyle fuel sender seals a while back that looked good but once installed and touched fuel they would swell up and ooze out.
        • parkerbink
          • Jun 2004
          • 10138
          A bit over 1/2 tank, I'll check the seal thanks!
          • salvageland
            • Aug 2016
            • 149
            I had same issue, it was leaking from the 4" hose connecting pump to hard lines. Remove the rear seat bottom, access plate to fuel pump and replace hose or tighten clamps. Hose is 5/16" ID and available from Autozone/Pepboys.
            • parkerbink
              • Jun 2004
              • 10138
              Thanks, it was the passenger side fuel level sender O ring.
              • MR E30 325is
                • Dec 2008
                • 3300
                Glad you got it figured out!
                My previous build (currently E30-less)
                http://www.r3vlimited.com/board/showthread.php?t=170390
                A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                • parkerbink
                  • Jun 2004
                  • 10138
                  Thanks.
