Speed sensor connector part number?
  • Dave_G
    • Feb 2007
    • 71
    I made the classic brain fart of dropping the diff in my E30 and forgetting to disconnect the speed sensor, so of course the wires broke. The connector is this 90-degree one:
    It's kind of falling apart anyway, so I've found a replacement online for the housing. But I'm having a hard time finding something that identifies the individual elbow connectors, i.e.the two that are shown here:
    Does anyone have a BMW part number for these? I think it might be 61131382246 or 61130007446, but it depends on the diameter of the pins, and I don't trust myself to identify the pin size accurately. I could also just find something close at Radio Shack, but I'd rather have the real thing.
    Dave
    '91 325iX
  • mr.vang
    • 4371
    I have couple pigtail laying around. Let me know if you're interested.
    • jeffnhiscars
      • Jun 2011
      • 6011
      I bought those connectors. Will see if I can dig up the PNs
      Alice the Time Capsule
      • TobyB
        • 5279
        There are 2 different connectors- I think it changed right about when the bumpers went plastic.
        t
          • 34844
          Pretty sure it's #3
          http://www.realoem.com/bmw/enUS/show...diagId=61_2489
          comes with a green pigtail wire - same ones used for the fog lights BTW.
          I need to check mine again, my speedo works about 75% of the time, lol.
          edit: yep
          https://www.ecstuning.com/b-genuine-...h/61130007445/
          • Dave_G
            • Feb 2007
            • 71
            Originally posted by nando
            Pretty sure it's #3
            edit: yep
            Yup, htat's the one, but it comes in two different sizes. One is 0.5-1.0mm, and the other is 1.0-2.5mm. I wasn't sure which size I needed, but a moment with the calipers tells me I need the larger size, which I've ordered. Thanks for the help, evreyone.
            Dave
            '91 325iX
              • 34844
              The smaller one is fine - its wire size in square millimeters. Its not a high power signal - but the bigger wires will work too. The pins are the same size.
              • Dave_G
                • Feb 2007
                • 71
                Doh! I should have realized that. I guess I'm too used to referring to wires by gauges instead of square millimeters. :)
                Dave
                '91 325iX
                • blueray0512
                  • Sep 2016
                  • 8
                  Plug number
                  but Plug housing number is? I can't find 2 pin and 90" degree black plug in catalog:(,
                  that looks like same the headlight plug, but just guess, cannot confirm, how did you solved it? Thanks!
                  • Dave_G
                    • Feb 2007
                    • 71
                    Check RealOEM.com. It looks like part #61131378418 might be what you're looking for.
                    Dave
                    Dave
                    '91 325iX
