Went To War With Bolt and I Won!
  • Echo30V
    • Sep 2017
    • 301
    So as you may or may not be aware, I am in the middle of a 3.73 LSD swap on my beloved Verty30. Well I disassembled the new/used differential for a refresh including a friction plate/dogear and seal replace. First, I cleaned it up then drained the gear oil, opened it up and all was good. Painted the case and things were lookin sharp.
    Then I finally received my ECS seal kit and new dog ears and friction plates from ThayerMotorSports. Excitement littered the air, gentle readers. I pictured myself sitting in the Verty30 blasting off the line, smiling as I blew past all the great unwashed. So onto the dreaded carrier cap bolts. You know, those 8 bronze, soft headed, 6mm dirty SOBs that are loctited into the clutch housing.
    Well, I was not going to fall into the stripped bolt trap, no not me, the Captain of the Verty30. I was going to take my time and carefully remove those bastards. So I started with a 6mm Allen socket on a 3/8 socket. Those bolts chuckled at my feeble attempts to loose them from their 27 year old dark holes. Onto the 1/2 ratchet...no luck. Then the Dewalt electric impact drill...not even a twitch from those bitches. Desperate times calls for the big artillary.
    Out came the air tools. Cranked up the air to 125 lbs and with a steady hand and steely cold stare I pensively with a light touch hit the trigger and joy oh joy that bolt came loose and backed right out. Onto the next bolt in a star pattern and “bazeet bazeet” out came those tortured souls, one by one. God I was so proud of myself to the point of almost being smug. BMW intelligentsia going on and on about how difficult these bolts are to remove and I was absolutely handling them like feeble flees.
    The last bolt lie dead ahead. I stopped and whispered to myself, “go easy big boy, you got this, we are home and onto the fun of repacking that clutch pack. “Bazeet, Bazeet, Bazeet.” Then horror, Dismay, Agony, Misery, Dispare, Anger, Panic, self loathing all filled my beer bloated brain. The damn bolt head stripped out and rounded into a perfect smooth circle and I was so pissed I just kept hitting that air gun trigger in the hopes the bolt would feel bad and jump out of the hole just because I’m the Admiral of the Verty 30. But alas, it stared at me with its rounded out insides smirking at my long gone smugness.
    How to get this bastard out? First I PB blasted it and waited. Put vice clamps on and nothing. Drove to automotive store and purchased the fanciest, shiniest most expensive vice grips I could find in the hopes that the bolt would be so impressed with my purchase it would roll over and give in. Well, that was a pipe dream...didn’t budge. Ok onto heat. I heated that bastard and PB blasted it and then heated it again. Nothing. Repeated the process, nothing. Repeat...nothing...Vice grip spin...nothing. Back to heat...no movement. Now I’m getting depressed and concerned. A day has already past and many many hours of toil.
    Tried something a bit crazy. Heated it up again, then took a big heavy chisel and 3 pound hammer and banged a nice dent in the side. Then angled the chisel and smashed it three or four times. Nothing. Banged the dent deeper. Then just like the fabled John Henry I raised my hammer and sang, “Oh John Henry, told his Captain, that a mans gotta act like a man and before that bolt beats me, I will die, with a hammer in my hand.” I let that hammer fall and the SOB moved a few millimeters. I laughed like a madman out loud. I hit it and hit it and hit it and booooom it was out. I WON! Here are my tools and the defeated SOB bolt.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
  • 1843lamp
    • Sep 2015
    • 276
    If you can weld/ have access to a welder you can weld a bar of steel to the head of the stripped bolt ,the heat should also help loosen it.
    • Echo30V
      • Sep 2017
      • 301
      Yes, I considered that route but I don't have access to a welder. Also considered JB Weld but was skeptical. The chisel and heavy hammer worked like a charm.
      • superj
        • Feb 2006
        • 397
        you went old school on it
        • Echo30V
          • Sep 2017
          • 301
          Yes, I like old school.
          • MPLFoster
            • May 2013
            • 1490
            Cool story. Congrats on the win.
            form.follows.function IG @mplfoster
            • AndrewBird
              The Mad Scientist
              • 11898
              These work well:
              Or the hammer and chisel method like you used works as well.
              • Echo30V
                • Sep 2017
                • 301
                I looked at those Irwin sockets but wasn’t sure. Do they cut into the bolt head?
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  The hole is tapered so as you turn, the edges dig in. The more force you turn with, the harder they bite.
                  I used one once on a downpipe nut that was rounded. It grabbed hard enough the bolt snapped off.
                  • Echo30V
                    • Sep 2017
                    • 301
                    Good item in which to invest
                    • Kershaw
                      • 11822
                      You can use an air chisel to do what you did a lot easier. I also have those irwin bolt extractors, they work great.
                      AWD > RWD
                      • jrobie79
                        • Mar 2006
                        • 2523
                        Originally posted by AndrewBird
                        These work well:
                        These things have saved my life numerous times. Every shop needs a set
                        1991 318i ---- 308K - retired
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          I find since the carrier cover is sprung, you can't leave one last bolt, you need to have the opposing side snug.
                          Great post, though!
                          Having rebuilt many diffs, I skip the drama and hit them straight away with an impact. Any that spin out gets an impact torx socket beat into the hole and they always yield. :)
                          john@m20guru.com
                          Links:
                          • ttrousdell
                            • Nov 2009
                            • 1770
                            Haha well written. Where on Long Island?
                            The Build:
                            • Echo30V
                              • Sep 2017
                              • 301
                              I’m in Holtsville. You?
