anyone has one or can provide the link?
E30 Torque manual
Does someone have the full BMW torque value book for the E30?
I've found this one online but I'm pretty lazy to download them all lol..
Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
Your resource to tools and tips: www.rtstools.comComment
John,
here is a link to TIS that says all models with M10 8.8 - 45nm. What do you think 22 or 45?
Well admittedly I had not considered the diff busing. load yes, but its still only m10 bolts and there are like 10 of them? Each to their own. unless you have a tiny torque wrench designed for those small numbers then the larger torque wrenches are too innaccurate and you risk breaking the bolts anyway.Comment
there are 8 bolts. I think cover would crack way before bolts will brake and 45nm isn't such a small torque. M10 bolts are not small at all. M12 (next size up) is the largest bolt in the whole suspension setup. I think the largest bolt in e30 is M14 (2 rear subframe mounting bolts)Comment
Largest bolt in an e30 is 18mm x 1.25, largest nut is 48mm x 1.5 :pthere are 8 bolts. I think cover would crack way before bolts will brake and 45nm isn't such a small torque. M10 bolts are not small at all. M12 (next size up) is the largest bolt in the whole suspension setup. I think the largest bolt in e30 is M14 (2 rear subframe mounting bolts)Last edited by ForcedFirebird; 02-19-2018, 05:15 AM.Comment
