Camshaft journal scoring - need advice
  • Codym42
    • Mar 2013
    • 611
    I found a set of s52 cams but they have some scoring. They have around 150k miles on them. Would you guys buy these if you were me? Are they bad?
    Sent from my Moto G (5) Plus using Tapatalk
    '90 325i - 5 speed coupe
    '05 330ci 6MT ZHP
  • e30davie
    • Apr 2016
    • 1788
    Can you feel the lines witg your finger nail?
    • Codym42
      • Mar 2013
      • 611
      The seller says that one of the marks does catch his fingernail a bit
      '05 330ci 6MT ZHP
      • e30davie
        • Apr 2016
        • 1788
        I think the general rule is if you can feel it with your fingernail its too deep for use.
        Others may chime in with their opinion.
        • zaq123
          • Jul 2016
          • 1512
          it's not the end of the world and pretty common. As long as cam lobes are perfect and there are no raised edges on the journals, should be ok. if there are any raised edges, knock them of with some scothbrite, wash the cam, lube and install
          • DaWildBeast
            • Mar 2016
            • 244
            I wouldn’t... save yourself the headache and get new cams. Just my o2
            • Codym42
              • Mar 2013
              • 611
              Thanks for the input everyone!
              I think I may just go ahead and get them. The scoring doesn't seem that bad especially compared to most higher mileage m/s5x cams. Worst case scenario is I take them to a machine shop and have the journals polished.
              '05 330ci 6MT ZHP
              • st.petebiodiesel
                • Jul 2015
                • 211
                I’ve ran cams with way more scoring than the ones pictured. Just think of the score in the journal as an extra oil way. As long as it’s below the surface of the journal it’s fine.
                It’s not like the thing is going to snap in half.
