HELP my trunk is stuck battery dead
  • 325isgao
    • Sep 2018
    • 20
    My trunk is stuck because I think the trunk need power to unlock and battery dead is there any way to charge the battery under the hood
  • uturn
    • Dec 2010
    • 1008
    The positive terminal is on the firewall, the negative is on the strut tower.
    Why do that when all you do is insert the key into the trunk lock, turn the key to unlock it (horizontal ) and press in to release?
    • 325isgao
      • Sep 2018
      • 20
      my lock on the back
      It dose not work I have to unlock it from the passenger side it’s electronic so need power
      • AndrewBird
        The Mad Scientist
        • 11898
        The actual lock cylinder in the trunk will turn with the key without power unless it is broken.
        • 325e '87
          • May 2017
          • 503
          Yeah, the trunk opens with the key and you press the button in, it’s mechanical. The electric part is how it unlocks the doors when you unlock the trunk.
          Can you open the driver side door? Do that, pop the hood, charge the battery.
          If you lock system electronics have completely failed you may not be able to open the fuel door, depending on your year model.
          My son has the 1987 325e, 2 door, 5speed
          I daily the 1989 325i, 4 door, 5speed
          • moatilliatta
            • 6158
            Probably since the car is in canada the trunk key operation is all seized up.
            @Zakspeed_US
