Electrical Battery Issue!!!!
  • MannyCooks
    • Oct 2018
    • 6
    Sup guys,
    So I've been having this electrical problem with her for almost a year already and I've taken her to 2 mechanics and no one can find out the issues. So once I fully charge the battery (Autozone) the car turns on and runs for maybe about an hour until it completely dies. No power whatsoever. Completely dead. I thought it could be an alternator issue but its not. Thought it could be the alarm system so I took it out and still the issue continues. Any idea guys?
    Thanks
    Manny
  • agent
    Vice Grand Pubaa
    • 7960
    The FAQ/DIY section is for staff-approved instructional posts only. Please do not ask questions there. If you don't know where to ask your question, post it in General Technical and we'll move it to the appropriate subforum if necessary. Thanks in advance.
    Originally posted by kronus
    • slum dog
      • Jun 2017
      • 110
      You only get a hour from a fully charged battery, how was the alternator tested?
      Does the battery light come on with ignition and go off when the car starts??
      I had a battery 12.6 volts off, while car running 12.9 /13volts but once I turn anything on that demands power like aftermarket sound or head lights the battery would drain dead.
      Changed regulator brushes bumped it 13.7 14.2 depending on rpm.
      No issues after that
      • dnguyen1963
        • Nov 2011
        • 2649
        Correct me if I'm wrong, but I remember reading somewhere that in the early cars (pre-1986?) a damaged SI/instrument board would prevent the battery from being charged.
        • slum dog
          • Jun 2017
          • 110
          The charging system works with the battery bulb on instrument board so I believe you are correct.
          • be34st
            • 1277
            I'm having the same exact problem with my 84 318 that has been M20 swapped. I inspected the wiring and everything looks to be in working order.
            I noticed a day ago after charging the battery up, starting the car, and letting it run, that the tach is dead. I obviously have an issue with the instrument cluster and wonder if my electrical/no-charge issue is related.
            OP please share in progress you make with this issue. Thanks.
            07 Designio E63 AMG / 1984 318i (M20Swapped)
            • e30davie
              • Apr 2016
              • 1788
              yah i would be curious to know how the alternator was tested. Should be 12V -ish when not running, and over 13v when running.
              If the SI board or whatever is playing silly buggers you should be able to bypass it wire the alternator straight to the battery, you just need to put any old bulb (NOT LED) where the bulb goes, as its the exciter.
              An auto electrician worth anything should have been able to diagnose this issue in about 5mins.
              • jeffnhiscars
                • Jun 2011
                • 6010
                How do you test alternator voltage output with the car not running :)
                Alice the Time Capsule
                • dnguyen1963
                  • Nov 2011
                  • 2649
                  You can...just get 0V that's all.
                  • jeffnhiscars
                    • Jun 2011
                    • 6010
                    Well...that's not really a test is it :)
                    • reelizmpro
                      • 9531
                      LOLLLL that's rich.
                      88 M3 - LACHSSILBER
                      89 M3 - ALPINEWEISS II
                      • reelizmpro
                        • 9531
                        Originally posted by MannyCooks
                        Sup guys,
                        Thanks
                        Manny
                        What is the year and model? How did you check the alternator? if you have a pre 86 cluster, a faulty battery bulb or bad contacts on the instrument cluster could cause the alternator to not charge the efficiently.
                        88 M3 - LACHSSILBER
                        • slum dog
                          • Jun 2017
                          • 110
                          Well my buddy has a home built rig set up, basically its just a bench vise modified with adjustable brackets so most alternators bolt on.
                          It then runs on a belt to a air compressor motor which turns at 850 rpm and has you press down on the foot pedal it picks up rpm to around 2500
                          I also seen those old toppies us a heavy duty drill.
                          • slum dog
                            • Jun 2017
                            • 110
                            You could do what he says
