Does Seafoam work?
  • e30_jake
    • Mar 2019
    • 12
    Does Seafoam work?
    I heard a bit about Seafoam and other products that clean up your engine and such by taking out carbon deposits, and how it can smooth the engine up and such. I was wondering if anyone had any experiences with this, good or bad. I'm looking to get some for my '91 E30 318i Cabrio. I've got the M42B18. It kind of sounds like a diesel but otherwise runs fine, just hit 180,XXX. If anyone has any tips or suggestions, send them my way, thanks.
  • wworm
    • Dec 2016
    • 1719
    HHHHEY GUISE
    1984 Delphin 318i 2 door
    • McGyver
      • 4636
      Does Seafoam help to clean out deposits on a dirty engine? Yeah.
      If your engine "runs fine", will it help? Probably not.
      I wouldn't waste time/money throwing products at a car without a specific problem I was trying to fix. So unless you identify an issue, troubleshoot it to find the cause, and then fix it, I would leave it alone.
      Stick to regular maintenance with quality parts. Change your oil/filter regularly. Only buy top-tier gasoline. Flush your brake fluid every 2 years. Flush your coolant if it looks nasty. Change the air filter when dirty. Get new wiper blades so you can see in the rain. Wash the road salt off the car. Etc.
      • agent
        Vice Grand Pubaa
        • 7960
        General Discussion is not a catch-all; please do not ask technical questions there. If you don't know where to ask your question, post it in General Technical and we'll move it to the appropriate subforum if necessary. Thanks in advance.
        Originally posted by kronus
        • roguetoaster
          Biggus Tippus
          • 7830
          Replace your timing chain tensioner, listen to your lifters, one of those is likely the issue. Basically any detergent heavy engine oil changed a couple of times with good old Italian tune ups will help to clear out the oil passages.
          • TobyB
            • 5296
            I gargle with it every morning.
            My dentist says it works great.
            t
            • roguetoaster
              Biggus Tippus
              • 7830
              t
              I guess if you use your exhaust stream as a Waterpik then Seafoam might be the right choice.
              • E30-Ellerman
                • Oct 2015
                • 212
                I like it personally. I wouldn't run it on a turbo car but for an NA car I like it. I used it on my previous V8 4Runner with 300,000 kms every 10,000 kms through the intake and it burned off a ton of carbon and ran smoother. I never had an issue with it.
                2016 F-150
                1987 Royalblau 325es B25 turbocharged
                Build thread here: http://www.r3vlimited.com/board/showthread.php?t=405594
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  It works great for sticky lifters when used in oil, but I generally don't burn it in the combustion. The LS in my Chevy van had a ticking lifter recently, half a can of Seafoam cured it in a day.
                  Water has a very similar effect for breaking carbon. I used to use water in my old VW air cooled Beetles.
                  john@m20guru.com
                  Links:
