Heater constantly blowing air...
  • tusamni
    • Oct 2006
    • 29
    My heater in my 325iX will constantly blow air. It doesn't matter if the switch is on 0,1,2,3 or 4.
    It seems like it's always stuck on the 1 setting or so. If I want to turn it off I just have to put all the horizontal switches to the left.
    It will blow cold air, but I have had it on heat mostly since it's been COLD up here lately.
    Blower motor maybe? I thought it might be the blower resistor pack like everyone else's problem, but it doesn't change on the 4 setting like everyone else?
    Thanks
    -Erik
  • AdamF 88iS
    • 2051
    Do you have teh AC or recirculation buttons pushed? Those force fan speed 1 even if the switch is off.
    Do you still get air when the car is stopped?
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • tusamni
      • Oct 2006
      • 29
      Both A/C and Recirculation buttons are off, and if I turn the car off the heater is also turned off.
      When I cold start the car, it's hardly blowing out, then as it warms up it picks up a little, but it still feels like maybe level 1, maybe 2 at max...
      Thanks
      -Erik
      • moatilliatta
        • 6151
        put it on cold then it blows cold air. mines done the same for years....
        @Zakspeed_US
        • tusamni
          • Oct 2006
          • 29
          Sorry I think I sort of messed up when writing this...
          It's not just blowing heat, if I change the temp I can get cold air, it's just that i've only been blowing hot air, since it's chilly up here. But I can get cold air.
          The problem is that no matter what speed setting it is on (0,1,2,3,4) I get the same amount of air.
          And if I stop I believe I still get hot/cold air blowing. But I am at work right now and can't check that out for sure.
          Thanks so far
          -Erik
          • moatilliatta
            • 6151
            Now that im thinking about it. does it happen when your moving or staying still or both?
            @Zakspeed_US
            • tusamni
              • Oct 2006
              • 29
              I am gonna give this a try on the way to school tonight and ill post after I am out...
              -Erik
              • porsche gt1
                • 237
                your switch needs to be replaced my best bet.
                • tusamni
                  • Oct 2006
                  • 29
                  OK so new update...
                  As soon as I get up to speed it starts blowing slightly, cold or warm, whatever I set it to. As soon as I come to a stop, all the air stops coming out.
                  Not sure what this means...
                  Thanks
                  -Erik
                  • parkerbink
                    • Jun 2004
                    • 10138
                    I thought it was spelled heeter.
                    • AdamF 88iS
                      • 2051
                      Originally posted by tusamni
                      OK so new update...
                      Thanks
                      It means nothing is wrong. Air comes into the car when you move and have the vents open; especially if you have the sunroof or windows cracked open.
                      Adam Fogg- '88 M3
                      • tusamni
                        • Oct 2006
                        • 29
                        But the switch still does nothing? So I should replace the switch then?
                        Thanks
                        -Erik
                        • moatilliatta
                          • 6151
                          Oh so the switch does nothing 0-4?
                          Edit. if thats the case its prolly the blower moter and not the switch. ive seen more moters go bad then switches.
                          @Zakspeed_US
                          • tusamni
                            • Oct 2006
                            • 29
                            Correct,
                            Here are some totally awesome PS images I made :p
                            1st Scenario
                            So here the air (whether hot or cold) is off. Nothing comes out no matter what speed the car is moving at.
                            2nd Scenario
                            So here the air (whether hot or cold) is coming on. The speed of the air corresponds to the speed of the car.
                            3rd Scenario
                            So here the air (whether hot or cold) is coming on. The speed of the air corresponds to the speed of the car. The difference is that I have changed the speed to '4'. Yet the same amount of air is coming out in scenario 2. The move to speed 4 does nothing.
                            The images probably just made things more confusing, but I hope they did something.
                            Thanks
                            -Erik
                            • moatilliatta
                              • 6151
                              the images made me laugh. nice visual. check the blower moter see how well its spins. its prolly toast. never know though. i hope its a switch cuz switches are much cheaper than a moter.
                              @Zakspeed_US
