e30 sus.
  • e30fan
    • Mar 2004
    • 64
    e30 sus.
    ok guys heres the suspension i have decided on...let me have it now..im new at this ok..this car with be a dual duty car for now,so..im going with the H&R springs 1.3 drop,Bilstine sport shocks,bmpd front and rear sway bars,and bmpd front strut tower bar, Kose K-1 wheels 15/7,with Yokohama ADVAN 225-50-15 tires..so good and bad i want to hear all sugestions..thanks alot guys..Jay
    • 34846
    sounds like a good all around setup to me. :)
    • e30fan
      • Mar 2004
      • 64
      damn thats great...now what will have i have to upgrade when the car becomes a decaiated track car...?..thanks..Jay
      • Charlie
        kid tested, administrator approved
        • 6686
        Sounds like a great setup, pretty much what I'm running right now, save for ST sways and soon to be a set of RA-1s as opposed to the advans.
        When you say "dedicated track car", the sky's the limit. It really depends on what the further plans are for the car once you make it a full on track vehicle. I'm eventually going to go with the Turner "j-stock" springs & custom valved bilsteins, my overall plans are to run the car in k-stock, which doesn't allow coilovers. That being said, if you're just going balls out, then a C/O setup with some properly valved Koni SA's (or DA's if you have the checkbook for it) would probably be ideal. It allows you a wide selection in terms of available spring rates, and allows you to easily cornerweight the car.
        -Charlie
        Swing wild, brake later, don't apologize.
        '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
        FYYFF
        • e30fan
          • Mar 2004
          • 64
          damn thats sounds like a bad ass set up...what about KW coil overs..how would they be for the track car...and the advans are gonna be switched for hoosiers..thanks..Jay
          • MattM20
            • 641
            if you got the $$$ then i'd go for the koni SA's instead of the bilsteins
            • m42technic
              • 1056
              Dont forget bushings :)
              James Peacock
              WWFSMD?
                • 34846
                actually, since he's just using H&R sports, bilstiens are more than enough. the adjustability of the koni is nice, but not neccesary. if he was going with coilovers or something, then konis might be needed. Remember, specE30 uses bilstien sports with H&R race and it performs fine.
                I need konis on my car, they don't make bilstien sports for an ix and bilstien HD aren't enough to control the springs.
                bushings on the other hand, are highly reccomended. if you're putting stiff suspension on a car with 15 year old bushings, your handling will be quite strange.
                • MattM20
                  • 641
                  $150 extra for 3-way adjustability on all 4 corners is worth it imo. and since he's getting sways and a strut brace it may push pretty hard with bilsteins.
                  • MikesJo
                    • Mar 2004
                    • 989
                    What kind of bushings would he need? How about RSM's? Is it a 318is your putting this on?
                    Vancouver Portrait Photographer
                    E30 M3 Wallpapers
                      • 34846
                      trailing arm, subframe, and control arm bushings, possibly strut mounts and control arms depending on their shape. if you bother with bushings, go with all eurethane (except maybe the control arms, M3 offset work great).
                      my buddy's car has completely shot subframe and trailing arm bushings.. boy is that thing fun to drive in the twisties
                      • e30fan
                        • Mar 2004
                        • 64
                        ok guys,this is a 1986 325 ..so what bushings would i need to replace..and yes i may upgrade to the konis when i get my motor back in my civic,remeber this is a dual duty car for now...also what is the biggest tire size that i can go with ..i was told that the 225-50-15 would be great....you guys are great,,,thanks alot..Jay
                        • MikesJo
                          • Mar 2004
                          • 989
                          Newbie question: What do bushings do? :D
                          E30 M3 Wallpapers
                          • Jordan
                            • 12916
                            They act as a buffer between Texas and the US.
                            https://mtechniqueabs.com/
                            • 1985bmw325e
                              • Mar 2004
                              • 474
                              you must live in japan or you must have a lot of money to buy these type of tires.... have fun trying to find them for a decent price
