Would BILSTEIN STRUT INSERT fit BOGE's
  • BingM3
    • 863
    Normally when you change your STRUTS, it is only the insert that gets changed right? Right now, I have BOGE's STRUTS. If I buy the Bilstein Touring insert, it should fit right?
  • m42technic
    • 1056
    Youll need the gland nuts provided with the Bilstein Tourings, but yes.
    James Peacock
    WWFSMD?
    • BingM3
      • 863
      "gland nuts"???
      • Mystikal
        Wheel Fitment Expert
        • 9602
        Recalling your past thread, I hope you're not planning to run Bilstein Touring shocks with lowering springs.
        • BingM3
          • 863
          Aren't the Bilstein touring struts shorter to complement the lowering springs?
          • Bitburger
            • Jan 2004
            • 147
            I think you're confusing Bilstein tourings with the sports. The tourings are more of an oem type shock whereas the sports have a shortened shaft to accompany a lowering spring. Hope that helps
              • 34844
              no. they're just standard length bilstiens, probably about the same valving as factory shocks.
              and by struts, you have Boge inserts. the strut tube itself is a seperate peice that you put the strut insert into.
              don't most new shocks come with the gland nut? You pretty much have to destroy the old one to get it off since they tend to rust onto the strut.
              • Mystikal
                • 9602
                Correction: Tourings have exactly 15% more gas pressure than stock. :D
                  • 34844
                  which is pretty much the same ;)
                  I suppose if you want to keep the stock ride though, tourings would be a good bet.
                  • Stu Mc
                    • 4083
                    And how much stiffer are H&R sports than stock springs? 15...20%?
                      • 34844
                      I dunno.. I do know that my suspension is far stiffer than stock, but it might be the konis affecting that. I really doubt tourings are significantly stiffer than OEM, at least in the noticeable sense. they should last longer though.
