Front tires off center
  • Jordan325iC
    • Aug 2005
    • 1697
    Many months ago I hit a curb with both the drivers side wheels (hard enough to pop both tires and bend the front rim).
    The car steering has a heavy tendency to the left. The front drivers side wheel is noticably closer to the door (~1.5") than the passenger front wheel.
    Here is a dramatic recreation of my problem.
    I've swapped out the strut assemblies. Everything looks straight and bolted back in without issues. Anybody have any idea what could fix this problem and get my steering back where it should be?
    '88 325is
    VP UT of Austin Autoholics
    BMWCCA 380364
  • PiercedE30
    • Apr 2005
    • 4220
    open the hood, measure from the rear upper strut mount bolt to the firewall on both sides. If you did enough damage, you may have actually moved your upper mount towards the firewall some. Also, how are your control arms and bushings?
    My 2.9L Build!
    • Mike325
      • Mar 2006
      • 3685
      Did you have an alighnment done after the accident? Sounds like you bent the strut tower or the control arm. You have a caster problem.
      Originally posted by Kershaw
      • Jordan325iC
        • Aug 2005
        • 1697
        The control arm very well might be bent. I had a very hard time getting the old one bolted back in. I've got a brand new one and bushing that I could install.
        '88 325is
        BMWCCA 380364
        • PУCCKAЯ_e30ka
          • Jan 2006
          • 1226
          it must be control arm! the strut tower whouldn't move. It's control arm... ask me how I know! ;)
          • moatilliatta
            • 6123
            how do you know?
            @Zakspeed_US
            • ddavidv
              • 344
              I also vote control arm. Most common failure on an impact like that.
              • Teaguer
                • Sep 2004
                • 6167
                Yes control arm .
                If you've got a new one get your ass of the computer and slap it on already . Gosh !
                  There's a good chance that both control arms were bent in an incident like that. So replace both of them.
                  • markseven
                    • Sep 2006
                    • 5327
                    Get a nice four wheel alignment done. Whether or not the tech can bring the caster within spec will shed light on your situation. IMHO, an alignment is mandatory after hitting a curb hard enough to bend the rims and pop the tires.
                    I Timothy 2:1-2
                    • ZiMMie
                      • Jun 2004
                      • 968
                      Control Arms.
                      Chk them
                      www.stancefactory.com
                      • asubimmer
                        • 6482
                        you realize the e30 has only one adjustment from the factory?
                        • Jordan325iC
                          • Aug 2005
                          • 1697
                          Alright, alright. I'll do the damn control arm! :D
                          '88 325is
                          BMWCCA 380364
                          • markseven
                            • Sep 2006
                            • 5327
                            No camber, caster or toe adjustments?
                            I Timothy 2:1-2
                            • asubimmer
                              • 6482
                              rear is fixed and the front only has toe adjustments
