M30 afm help
  • nateb
    • Apr 2004
    • 54
    Heres a pic of mine just for the hell of it.
      • 34839
      it will fit if you line up the big6 afm in the same posistion as the stock one (they are the same size on the outside). I had it all lined up and read to make a bracket for it. but yeah that filter is pretty damn big. :P
      • rwh11385
        lance_entities
        • 18403
        Bryson, Nateb,
        where are your guys' ABS pumps/cruise controls? Coolant reserve?
        I don't have any space in mine for any filters.......let alone a huge ass one.
        Note: stock boot does fit, even though I was disbelieving......
        Doesn't fit so well.......... :roll:
        • Saul325is
          • 819
          Well one thing, that is a huge fucking filter, and it should fit. Well at least mine does. Is that some kit from BMP or somthing? Weird. I used the Boot off of an e34 M50 and it worked fine (extended it out far enough).
          -Saul
          Saul
          01 330ci Daily Driver
          89 332is Auto-x Friend
          95 M3 *SOLD*
          87 325is *SOLD*
          • nateb
            • Apr 2004
            • 54
            I have an 87 eta and the coolent resevoir is on the passenger side on mine. Basically when I take out my old air box I have nothing in that area.
            • rwh11385
              lance_entities
              • 18403
              Is that some kit from BMP or somthing? Weird. -Saul
              :twisted: Looks like a kit, doesn't it? 8)
              Nando cleaned it and crinkle painted it. I just used the stock boot and it worked fine.
              Looks real clean. I need to get a spare airbox and M20 AFM (maybe), I'll mod the airbox to fit the bigger AFM, which will also give a good way to mount it.
              The AFM is so heavy, I don't trust some metal straps to hold it, and the airbox should give a clean look.
              And while I'm at it.....I'll do the swiss cheese airbox mod ;) Gotta love the sound :up: I'll have a spare box anyhow.
              Probably will clean the box up or paint it black again. Should look real clean. If only I knew if I needed to swap the electronics or not.
                • 34839
                making it fit on the stock airbox wouldn't be too hard. you'll have to enlarge the inlet hole, it's much bigger on the M30, and bolt it directly to the AFM (unscrew the peice that connects to the cone and use those thread holes, like the M20). I still think you could make the cone work, although there may very well be more room in my ix engine bay, but my coolant resivior and cruise control are in the same place.
                you should get it working first though. :)
                • rwh11385
                  lance_entities
                  • 18403
                  yeah, Ely's technical thread for the mod was tight. Looks at the parts, and seems easy. Plus, dremels rule! :twisted: And power drills. 8)
                  • Bryson
                    • 1490
                    shit, mine fit fine, but go back into the thread where i showed you my intake box pics, you'll see that my cruise control is mounted away from the air intake
                    btw, i finished the air intake and it's a-mazing, I have pics on my shitty camera that i need to upload
                    • Saul325is
                      • 819
                      Here are some pics of my install, if it helps at all
                      now no more whining ;)
                      -Saul[/img]
                      Saul
                      95 M3 *SOLD*
                      87 325is *SOLD*
