Best location for oil temp sender on e30
  • DCColegrove
    • 2748
    Flow isn't what you need for accurate oil temp readings, immersion in oil is.
    The mass of the filter housing (or any other engine part will skew the readings).
    You can either trust me on this one or not... However, I can tell you I've had engines on the dyno with more than 20 temp probes in various portions of the oiling system.
    ...not to mention every other place you could imagine.
    • matt
      • 3732
      You would have to try pretty hard to get a location that doesn't give valuable information. For what we're doing here, which is basically A) making sure a motor has warm oil before working it and B) making sure the oil stays in an acceptable range, the absolute temp is not as important as comparing the current temp to a normal running condition. Ditto oil pressure.
      • DCColegrove
        • 2748
        True... however.
        There are cases (I can think of three...bet you could too if presented with the puzzle) where the oil filter block will intermittently give you a grossly inaccurate temperature reading.
        • franco90
          • 3185
          Originally posted by James Crivellone
          Why buy an adapter when you can simply tap the center of the oil filter housing bolt?
          Costs next to nothing, and does not require an adapter (not a fan of those)
          can you show me a picture of this in your engine. where can I get one of those.
          I've always been proud of being a Marine.
          I won't hesitate to defend the Corps
          "Supersquad"
          ‎"Prostitutes are a sub-category of Amusement Parks"-
          • James Crivellone
            Head Janitor
            • 6305
            e30 m3 temp sender from anybody who can get bmw parts, and the hollow bolt you already have on the motor (if you have an m20b25)
            • Uber E30
              • 1409
              Is there a solution like this for an s50?
              -Alex
                • 34844
                Originally posted by DCColegrove
                Oil temp senders should always be in the sump (Oil pan).
                Why you ask?
                Because that's the rule...
                (and the only place for an accurate oil temp reading).
                wow, old thread
                and yet another reason why nobody should believe a word this guy says
                • Uber E30
                  • 1409
                  Yeah i know its old would rather just search/bump instead of making a new one. I know of the UUC oil cap but looking for a more... economical solution.
                  -Alex
                    • 34844
                    are you just doing a temperature sensor, not pressure?
                    the VDO pressure sensor has a built in pressure switch that you can use to wire up the dash light. Convienently, their temp sensor threads right into where the stock pressure switch goes. So if you have a pressure sensor (I know some don't like it, but threaded into the hollow bolt works for me) you can remove the stock switch and replace it with a temp sensor.
                    if you are just doing a temp sensor, you can thread it into the hollow bolt.
                    do NOT put it in the oil pan, despite what our resident liar has to say, that's the worst place for a temp sensor. You'll never get a temp reading untill your oil is very hot, and then it will still read much cooler. Unless you think a temp of 140 degrees on a 95 degree day after sitting in traffic for 5 hours is "accurate". :p
                    • Uber E30
                      • 1409
                      Yeah just a temp sensor, im running an m3 cluster. Which bolt on the s50 are you talking about? Im assuming number 13 here:
                      I didnt even realize number 14 was there can i just pop that out and stick the e30m3 temp sender in there or do/should i run that pressure sender too?
                      -Alex
                      • gazellebeigem3
                        • Jun 2005
                        • 3712
                        Heres my choice:
                        • Uber E30
                          • 1409
                          link doesn't work
                          -Alex
                          • reelizmpro
                            • 9558
                            They just tap the banjo bolt fitting...number 13.
                            88 M3 - LACHSSILBER
                            89 M3 - ALPINEWEISS II
                            • fporro
                              • 1860
                              VDO makes nice ones, tee off pressure sensor port @ 5Bar.
                              Temp from oil pan drain plug, ither 17 or 19mm @ temps of 150c/300f range
                              • george graves
                                • 20003
                                Hey Nando, I don't know about this one, I've read a few things to suggest that oil pan IS the best place to get a stable oil temp. Sure the oil pan will act as a heat sink a bit, but I can't think of a better place where these is more oil, and less heat from other components then the pan it's self.
                                Can you convince me otherwise?
                                Originally posted by Matt-B
