Neccessary to paint brake rotor hats?
  • Spaz
    Crazy Canuck
    • 2276
    Originally posted by UNHCLL
    I bet they are fake if you bought them off e-bay and they are silver.....
    nah they sell real brembo on ebau
    i haqve vht brake caliper paint...works the charms
    Cam .W '91 325is
    Spaz's 1991 Alpine White???? S52 Build Thread...
    • NC325iC
      • Mar 2004
      • 6565
      if theyre drilled i bet they were bought undrilled then drilled in a garage somewhere
      which as im sure you know isnt good
      • Digitalwave
        is a poseur
        • 6292
        You guys think I am that stupid? They aren't drilled, and I know for a fact they are real Brembo's.
        RISING EDGE
        • Spaz
          Crazy Canuck
          • 2276
          i never said ur stupid, brembo aftermarket rotors are the same as the oem...cause they are oem, and they do go on ebay cheap.
          Cam .W '91 325is
          • Digitalwave
            is a poseur
            • 6292
            I know, not you Cam, I was refering to NC.
            RISING EDGE
            • decay
              • 5637
              the cadmium-plated rotors i previously mentioned were silver.
              according to this page (supplier i bought from):
              pdm-racing.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, pdm-racing.com has it all. We hope you find what you are searching for!
              they can be either that or gold.
              past:
              1989 325is (learner shitbox)
              1986 325e (turbo dorito)
              1991 318ic (5-lug ITB)
              1985 323i baur
              current:
              • Digitalwave
                is a poseur
                • 6292
                How many cans of paint should I need to paint all four rotors and calipers? I was thinking 3 cans of base color, and 1 can of clear.
                RISING EDGE
                • bimmerphile
                  • 3495
                  you're going to get hi-temp clear? Why?
                  bling bling, y0!
                  3-cans should be more than adequate, TJ. The goal is rustproofing and minor cosmetics, not show-car steeze right?
                    • 34839
                    I used 1 can of high temp flat black header paint for all 4 rotors. taped off the rotor surface, painted them and they've held up great.
                    • Spaz
                      Crazy Canuck
                      • 2276
                      ditch the clear, get one can of rotor colour (black) and 2 cans of caliper colour....whatever suits your taste. make sure the bleeders are loose or else u'll need new calipers. be sure to tape off the bleeder port and the brake hose port....but u and your mutilple painting jobs should know.
                      lets see some after shots when your done.
                      Cam .W '91 325is
                      • Digitalwave
                        is a poseur
                        • 6292
                        Hmm, didn't think one can would cover all the rotors. So you guys think I should do the rotors black? That's a good idea actually, if I paint the throwing stars black. Then silver calipers.
                        RISING EDGE
                        • Spaz
                          Crazy Canuck
                          • 2276
                          your only doing the hat of the rotors so that takes little to know paint, tape off the rotor surface and most of the flat of the hat orelse they paint will get on ur rims when u mount them :shock:
                          Cam .W '91 325is
