To much carbon on my spark plugs after revving high....
  • denisbmwm5
    • 347
    I got a big problem, every time i redline line my engine couple times it starts to run very poorly and rough, i check the plugs and they got a shit load of carbon on them, so basiclly i gotta clean my fucking plugs alot. They are Bosch platnuims +2s. IF any of you know what this could be caused by, please let me know. thanks
    • 34839
    try using OEM plugs instead, they'll work better.
    • Jand3rson
      • 37587
      Re: To much carbon on my spark plugs after revving high....
      There's your problem right there. Use ONLY Bosch Supers in the M20.
      • denisbmwm5
        • 347
        You sure eurospeed??? but why do the still sell the +2 and +4s for m20? And whats the best porformence plug for my m20???
        • Digitalwave
          is a poseur
          • 6292
          Those plugs are just gimmicks. The best performance plug is still the Bosch Supers.
          RISING EDGE
          • denisbmwm5
            • 347
            Will auto zone or discount auto parts have the bosch super? and how much are they?>
            • Digitalwave
              is a poseur
              • 6292
              I am not sure who caries them, but they are $1-2 a piece.
              RISING EDGE
              • denisbmwm5
                • 347
                K THANKS GUYS,ILL DIFFANATLY CHANGE THESE PLUGS FOT THE BUPERS OR THE PLATNAUMS.
                • Beej '86 325es
                  • 2639
                  I have been running the same set of Bosch Platinum +4's for roughly 5 years. I've never had a problem with them and my car has 260,000 miles on it.
                  -Brandon
                  '86 325es S50
                  '12 VW GTI Autobahn DSG
                  '03 540i M-Sport (sold)
                  '08 Jeep SRT-8 (sold)
                  For sale:
                  S50 TMS chip for Schricks
                  • Jand3rson
                    • 37587
                    You haven't changed your spark plugs in 5 years? :shock:
                    • Beej '86 325es
                      • 2639
                      Not that I recall. I don't really have any running problems, but I probably should replace them anyway.
                      -Brandon
                      '86 325es S50
                      For sale:
                      • Jand3rson
                        • 37587
                        You may not have any obvious running problems, but I can almost gaurantee you that your car will run BETTER if you replace those plugs ASAP.
                        • Kavkazia
                          • 394
                          Any sign of oil?
                          You could have bad valve seals, I was running cheapest autozone plugs and they were alright, noticed nothing when I changed it to original Bosch's from stealer, I'm asking about oil because you could have bad valve seals which are causing the problem you have right now.
                          95' M3.
                          90' 325i Turboed.
                          87' 325eS Fixed.
                          • denisbmwm5
                            • 347
                            Kavkazia:were is the valve seal ????
                            • Kavkazia
                              • 394
                              To have it replaced, you're going to have to pull the head out, camshaft, two bar, clips, rocker arms, springs, and when you'll see the little rubber piece on each valve with little spring ring around it, thats valve seals, if it's cracked or hard, there is your problem with spark plugs.
                              95' M3.
                              90' 325i Turboed.
                              87' 325eS Fixed.
