Hubcentric spacers, and longer lugs?
  • Digitalwave
    is a poseur
    • 6300
    Originally posted by Mystikal
    The fronts will mount fine without a spacer if you run 215's or narrower, use a 5mm spacer if you want 225's.
    The rears need a 5mm, and run a 225 (if you want the Euro look and don't want serious fender work).
    I think you are confused. A 5mm spacer makes ET10, with a 16x9" rim that is going to stick a couple inches outside the fender.
    RISING EDGE
    • e30Matt
      • 5077
      Yeah. E30s like an offset in the 25-27mm range.
      An offset of ET15 + 5mm spacer = ET10. The rim is going to stick 15-17mm further out than your average wheel, or almost an inch further than your normal wheel and tire combo.
      Understand?
      • ColdAccord
        • 5926
        any ricer shop doesn't have longer lugs though
        some of them have various lug nuts, but noone has longer lug bolts
        and yes, i meant hubcentric ring not hubcentric spacer. but I was wondering if a spacer would be needed for either of the wheels, also
        Originally posted by blunt
        • UNHCLL
          • 8790
          www.discounttiredirect.com sells centering rings for many different hub bores.
          Below the radar...
          • Mystikal
            Wheel Fitment Expert
            • 9602
            And it needs to. Do you really think a 9" wide wheel will fit in the well?
            Understand?
            You have a poor understanding of rim width and offset. If the rim is 7.5" wide it will fit fine with a offset of 25. If a rim is 1.5" wider, it is wider in BOTH DIRECTIONS. If the offset is not lower, the wheel and the inside of the wheel well will be trying to occupy the same spot in reality.
            The "25-27" rule only applies to 7.5" wide wheels. For example, a 7" wheel looks better with 20 (the wheel is smaller, it needs to and can be pushed out further).
            • gstuning
              • 833
              9x16´s or 9x15´s will fit with ET15,
              no need for more spacers, just can´t run wide in the front, tirewise
              Gunni
              @ Prodrive / Aston Martin Racing
              • ColdAccord
                • 5926
                what should I get up front for the 7.5" rims. will 215s fit, or will I have to go 205?
                im hoping to get 225s on the back
                • Mystikal
                  • 9602
                  You could run 215's, but the only tire I can think of in that size (215/45/16) would be the Azenis Sport. I guess you could go with a 215/40/16 though (it'll go with the Euro look).
