Decided to do some preventitive maintenance on my perfectly running 88 325i cabby, so did the following:
Oil pan gasket (shortcut method used)
valve cover gasket
camshaft seal and o-ring
timing belt
reference sensor
coolant temp sensor
wires
cap
rotor
belts
hoses
water pump
plugs
coolant flush
I got everything at Bavarian. I double checked all my electrical connections and cleaned with contact cleaner.
SO, when it started, it ran pretty good cold, but once it started warming up, started stumbling at idle. I can rev it up and it sounds good.
Don't suspect ICV since it ran fine before.
Check engine light was on right after finishing installing the parts, but disconnected battery and reconnected and it was not on after that.
What the flying f***.
Any help would be appreciated- you guys have bailed me out in the past so don't let me down now!
(thats you stereoinstaller)
valve cover gasket
timing belt
reference sensor
coolant temp sensor
wires
cap
rotor
belts
hoses
water pump
plugs
coolant flush
