question on draining coolant
This topic is closed.
  • e30 dude
    • 67
    i'll be flushing and changing the coolant on my m20 this weekend, for the first time since i've had my e30.. i can see the drain bolt on the engine block, but it's not easy to get to.. im thinking of removing the drain plug from the radiator and then running the engine till coolant no longer flows.. is this OK? will it drain ALL the coolant?
    thanks..
  • ColdAccord
    • 5926
    hahahahahahahahahahahahahhahahaha
    Originally posted by blunt
    • Kruzen
      • Mar 2004
      • 5603
      Originally posted by ColdAccord
      fixed*
      Who doesn't love a little BBQ?
      Griot's Garage at a Deep Discount
      • BMW BMXER
        • 2325
        No No No No.
        Use the proper drain plug.
        Sold it.
        • Digitalwave
          is a poseur
          • 6299
          Take it to a shop, you don't seem to have a clue what you are doing.
          RISING EDGE
          • e30evolution
            West Werks
            • 1888
            it would get all the coolant out.... but you would be running your engine with no coolant in the head..... temeratures will rise way above ok levels in a mater of seconds
            http://www.westwerksauto.com
              • 34844
              make sure to set all heater controlls to MAX before you drain and bleed the coolant..
              • e30 dude
                • 67
                yes i will, thanks..
                i dont see how running my engine for a very short period, say less than 1 minute without coolant can hurt it. cars with leaks in their cooling system run for quite a much longer period, even with the temp needle reaching the red zone without any damage at all..
                • Jordan
                  • 12916
                  Duuuuuuuddeeee
                  https://mtechniqueabs.com/
