E36 Rack Swap - Which Fluid to use?
  • AlpinWeissDZ
    • Apr 2019
    • 19
    Essentially I swapped a late model E36 rack into my E30 and I’m unsure of which fluid to fill the PS system with. The rack calls for Pentosin Power Steering Fluid, however the pump calls for ATF. Which fluid should I use to reduce the chance of damaging anything?
  • roguetoaster
    Biggus Tippus
    • 7830
    Most leaks occur at the rack seals, and the pump can certainly work with out of spec fluids. So, in this case I'd give the PSF a try, but in all likelihood either fluid will work, and seal leaks or foaming/performance issues will be a roll of the dice depending on condition/what was run before in each.
    • bradmer
      • May 2016
      • 362
      Use the red fluid, ATF. It is what I have used on our e30's with or without swapped racks. Try Google search (in my kind voice) using - r3v / power steering fluid
      and there are lots of threads in here.
      Aloha
      https://www.r3vlimited.com/board/for...steering-fluid
      Swap out the steering pump reservoir if it's original, there's a filter on the bottom of that thing that could be 35 years old. It's cheap and easy to do at the time of swap.
      • E30Bastard
        Shimmy Shimmy Ya
        • Nov 2018
        • 245
        Red Atf for steering racks is what I got from this forum. I have a z3 rack running red atf for a year now with no issues but don't take my word for it. Research and quantify.
        "It wouldn't be there if it wasn't..." - Milton Berle
        1988 325iS - M20
        • jeffnhiscars
          • Jun 2011
          • 6011
          Ive done several e36 rack swaps and a.ways have used atf.
          Alice the Time Capsule
          • 128keaton
            • Apr 2020
            • 115
            M1 full synthetic ATF or Aisin WS ATF. Both fantastic.
            • TobyB
              • 5280
              Redlind D4 and D6 atf's have worked for me in E30, E36, E39 and E46 power steering systems...
              t
