Advice on brand , where to purchase in tank pump for 1987 325is.Connection rusted off
  • clydesdale
    • 631
    I am replacing the tank and when I went to disconnect the sending unit, I noticed that the connection on the fuel pump was hanging on by a thread. I am not sure if this can be repaired, or if I need a new pump. Genuine BMW is $400-$500. Any advice? Thanks.
  • Vincenze
    • Apr 2019
    • 1044
    It should look like this if you have a double pump setup.
    The ground connector must be connected to the pipe.
    https://www.ebay.com/p/1111136436?ii...RoCGAcQAvD_BwE
    • clydesdale
      • 631
      Thank you. So, that white, two pronged connector is what has simply rotted off the top of the pump ring. These pumps are pricey. Is this something that I may be able to repair? I suspect the wire is still attached to the actual pump. But, that connector WAS hanging on by a thread. All I had to do was look at it and it popped of the ring.
      • reelizmpro
        • 9558
        There are aftermarket alternatives that are relatively inexpensive. You can also buy used.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • Vincenze
          • Apr 2019
          • 1044
          I just checked. No aftermarket pumps are in stock. It was usually Airtex, now it's not available.
          • Vincenze
            • Apr 2019
            • 1044
            If it's just the connector, you can try to glue it back.
            Try Super Glue and then use scotch tape.
