Pusher Fan Conversion with A/C - Fan Mounting
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4508
    Hey R3V-
    I converted my car to a SPAL 16" pusher fan set up a while back when I didn't run A/C via the 'official fan wiring thread' method. In reassembly, I noticed there isn't a great way to physically mount the pusher fan to the condenser. What have you done to mount your electric fan to your condenser?
    Are two fans required when running A/C, or will the one pusher fan suffice? I'd just like to keep it the way it is wired, if possible, and not run the mechanical fan. I have space to convert the fan to a puller, but figured a pusher aux fan would still be required up front for A/C, and I used the aux fan wiring to run my pusher fan.
    If you have any info regarding running an electric fan conversion and A/C, I'm just essentially trying to gauge what is "normal".
  • jeenyus
    • Aug 2011
    • 2064
    I feel like a puller would accomplish what you're trying to do. If it's set up correctly, it's pretty darn efficient.
    • AWDBOB
      hooptie connoisseur
      • Aug 2013
      • 4508
      Oh I know, I just have a perfectly functional, cleanly wired and mounted pusher fan setup, so I would highly prefer to use what I have, if possible, instead of redoing the entire setup,
      • jeenyus
        • Aug 2011
        • 2064
        Can you just flip the fan blades and reorient it as a puller fan?
        • AWDBOB
          hooptie connoisseur
          • Aug 2013
          • 4508
          I am using the factory aux fan wiring, so if I used the fan as a puller I’d have to wire in another aux fan, which I don’t really want to do if I’m able to get away with just running this fan as a pusher, just on the condenser.
          • jeenyus
            • Aug 2011
            • 2064
            Ah, I understand now. Then I am of no help. To me that would mean I'd need both if I didn't want to just use a puller fan for both the temp switch and the ac.
            • AWDBOB
              hooptie connoisseur
              • Aug 2013
              • 4508
              Does your a/c work well with just using the puller for both?
              If that will suffice, and I can still use my current wiring setup, then I suppose I could be convinced into just buying a puller.
              • AWDBOB
                hooptie connoisseur
                • Aug 2013
                • 4508
                Update- couldn't find a clean way to mount the 16" spal pusher with the A/C condenser in place, so I tried to reverse the fan to run as a puller.
                The Spal motor does not have an internal diode so the wiring can be reversed to change fan direction which I verified, but sadly the fan blade cannot be flipped. Thus, a puller fan is required, which is one p/n away from the pusher.
                Medium Profile Spal Pusher Straight blade is 30101517, and the same fan in puller configuration is 30101516, running Condor fan brackets.
