Pulling the hood off...
    • 34844
    hey that's a great idea. I'll try that next time I have my hood off (hopefully not anytime soon!).
    • evil_twin
      • Nov 2007
      • 2965
      Originally posted by twright
      Here's the way I align the hood when I put it back on:
      1.) Put the hood back on the hinges with the bolts in and loosely tightened. They should be tight enough to hold the hood, but loose enough so that you can still adjust the hood position.
      2.) Line the opening in the body where the hood will sit, when closed, with towels. These towels should be on the edges of the fenders and front of the windshield where the hood interfaces.
      3.) SLOWLY and CAREFULLY close the hood. If you have done this SLOWLY and CAREFULLY, the hood will magically align itself.
      4.) Slowly raise the hood and tighten all of the bolts.
      5.) Close the hood and check the alignment.
      Good Idea.
      Paypal: vdang5@gmail.com
      Delta Auto Care
      2875-C Towerview Road
      Herndon, VA
      703.435.1375
      My Feedback Thread: Evil_Twin
      • twright
        • 707
        Thanks for the compliments.
        I'd like to claim it as an original thought, but some old guy showed it to me. :-)
        • dupemaster
          • 56
          Ok, so just assume that one may have taken the whole hing off before looking on the internetz to see what the best way would be. How does one line the hood up properly? mine is way off...
          • twright
            • 707
            Loosen the bolts up and follow my directions in the post above. (The post above with the towels.)
            • learningcurve86
              • May 2008
              • 715
              good idea :)
              also, removing the spring-loaded bar seems like it would be terrible. i wouldn't do that unless i I wanted to replace it or couldn't avoid it
              Greg
              • AndrewBird
                The Mad Scientist
                • 11898
                Another way to mark the alignment is to drill a small hole (1/8" or so) through each hinge into the hood before you unbolt anything. Then, after you put the hood back on, just put drills (or even nails would work) in the holes to align it, tighten the bolts up and you're done.
                • dupemaster
                  • 56
                  I tried this and it wont work. It's tilted, not just miss aligned. I think I messed up when I put the hing back on maybe I didn't put it on correctly.
                  • Adrian_Visser
                    • Jun 2006
                    • 2823
                    soooo a 23 post thread about putting your hood back on ehh cool, It really isn't that hard people come on get over it. my little brother with no mechanical experience at all (I had to walk him through putting the brakes back together the other day even) had no trouble getting it perfect.
                    '89 Alpine S52 with goodies
                      • 34844
                      turn the rubber stoppers on the corners of the radiator support (above the headlights) in or out to adjust the height of the front corners.
