E30 m3 ls1
  • shiboujin
    • Feb 2006
    • 2791
    I'm interested in seeing what you wind up doing for the brake booster.
    • MC Hammered
      • Jul 2008
      • 2076
      Sub'd as I am considering doing this swap too.
      My 1989 e30 s52 Touring... this is Betty
      My 1989 325i vert (sold)...this is Nina
      My 1991 M5 (sold)... this is Veronica
      Photo comparison: OEM vs aftermarket windscreen for a convertible
      • LSM3
        • May 2012
        • 340
        Non assisted brakes is not an option so I will be using a hydroboost system utilizing the bracket provided in this kit. If I figure out an assisted brake at a later time that does without this braket, then I will remove it. Right now it seems that it is the best solution. I'll provide a review on the kit as a whole when it arrives.
        V8 engine swap kit for the e30 BMW Platform
        • IronJoe
          • 2275
          Sub'd.
          F Purists, this is badass.
          '89 Schwarz E30 M3 Cabriolet Build
          • Cha Ching
            • 1668
            Originally posted by LSM3
            I'll probably do LS6 heads, cam and intake once everything is sorted out.
            Definitely sub'd and waiting to see more on this swap! love the suspension finish. What gains do you expect with the above mentioned add-ons?
            Also, what year motor/tranny are you using?
            • LSM3
              • May 2012
              • 340
              cai, exhaust, ls6 cam, heads, intake manifold and tune should yield 400hp fairly easily. Drivetrain is a 99' w/ 67k miles.
              • ethrtyiS
                • 8147
                sub'd.
                '89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5
                my feedback thread
                • Jason89i
                  • Sep 2004
                  • 875
                  excellent! now I know of 3 GMW e30 m3's.
                  old pic during mockup..... but you get the idea.
                  • 10Toes
                    Me Father Was A Tree
                    • Jan 2008
                    • 61222
                    There is at least 5
                    • shiboujin
                      • Feb 2006
                      • 2791
                      What the hell do people do for brake boosters?!
                      • Wanganstyle
                        • 2828
                        the local LS7 e30M I built a diff for fitted the ford hydroboost unit from the garret tvs kit. it barely clears the front apron but does fit in reasonably clean.
                        the driver side strut tower needs to be scalloped (and re-inforced)
                        • 10Toes
                          • Jan 2008
                          • 61222
                          I would use the massive boosterless setup, the hydro boost/linkage setup looks like shit and takes up a lot of room.
                          • shiboujin
                            • Feb 2006
                            • 2791
                            I'm looking into this for a 1JZ swap. the massive boosterless setup still won't work.
                            • 10Toes
                              • Jan 2008
                              • 61222
                              This is the hydro setup
                              • Jason89i
                                • Sep 2004
                                • 875
                                reverse mount pedals. boosterless with correct master / caliper and 6.25 pedal ratio. had a forward mount (essentially the same) with the s54. perfect pedal feel.
