Top Dead Center HELP
  • PCasil
    • Oct 2013
    • 23
    Since S14.net has been out of service for the past two weeks, I might as ask my questions here.
    I'm trying to change the head gasket of my E30 M3 and I noticed, today, the metal point that points to the line on the crank pulley to signify it's on top dead center (TDC) is a bit off. I must've moved the timing chain a bit that caused it to move a bit. Keep in mind I still have the cylinder head on. So my question is: Is it still possible to set my crankshaft at TDC before I remove my cylinder head? I'm a bit worried because it's not precisely at TDC because I haven't removed the cylinder head yet and it's supposed to be exactly at TDC by the time the cylinder head is removed. Any help is greatly appreciated! Thanks!
    P.S. I'm following the directions based on the KoalaMotorsports manual as well as the factory manual.
    -PCASIL
    IG: SJZOOSUAVEBOY
  • reno808
    • Oct 2013
    • 4
    Remember their is 2 top center. Make sure its on the compression stroke so the intake valve will be open. stick a long extension in the spark plug hole and make sure its at highest point....
    • PCasil
      • Oct 2013
      • 23
      Please take a look at my video..
      IG: SJZOOSUAVEBOY
      • PCasil
        • Oct 2013
        • 23
        Bump..Anybody?
        IG: SJZOOSUAVEBOY
        • spdracrm3
          • Sep 2009
          • 959
          your ok
          your fine to move it that tiny bit to the line pistons will barely move if at all as its so close to TDC, you probably find when re-installing it will move as you put things together, you just need to make sure marks are good with chain tight.
          it takes a lot of movement to get to a piston/valve contact point and if you are moving things by hand you would feel it stop and so wouldnt keep turning it past that point..
          Angus
          88 E30M3 X2
          89 325IX
          92 R100GS/PD
          • SamE30e
            • Sep 2007
            • 4319
            You're fine. Lift it off.
            You just need to be careful when putting it on.
            1985 325e 2.8 Turbo VEMS
            • reelizmpro
              • 9546
              Yes u can but doesn't have to be at tdc before removal. I'm guessing they advise it to make things easier when reinstalling? Not sure. It's easiest to find tdc with the head off.
              88 M3 - LACHSSILBER
              89 M3 - ALPINEWEISS II
              • PCasil
                • Oct 2013
                • 23
                Thanks guys! I'll take a shot of removing the head in a few days and have it sent to the shop to get it resurfaced.
                -PCasil
                IG: SJZOOSUAVEBOY
                • PCasil
                  • Oct 2013
                  • 23
                  Today I got the chance to remove my cylinder head before I headed to work, and this is what I found. Carbon deposits on top of the cylinders.
                  So my question is, is this normal? And how can I remove the carbon deposits on top of the pistons without disassembling the pistons? I bought engine degreaser but I'm not really sure if the safest bet without your guys' approval first. Any recommendations on how to safely remove and clean the top of the cylinders?
                  -PCasil
                  IG: SJZOOSUAVEBOY
                  • reelizmpro
                    • 9546
                    Yes, to a degree. Mechanics will typically clean them up with a wire wheel.
                    88 M3 - LACHSSILBER
                    • PCasil
                      • Oct 2013
                      • 23
                      Should I keep it on, or should I remove it? I'm hearing a lot of mixed reviews regarding to keep it on or removing it..
                      IG: SJZOOSUAVEBOY
                      • reno808
                        • Oct 2013
                        • 4
                        Easy off the oven cleaning product works REALLY well make sure you clean up after it really well and your good to go
                        • uturn
                          • Dec 2010
                          • 1004
                          shiny pistons
                          I use brake cleaner, wooden dowels(aka chopsticks) and buckets of elbow grease!
                          • PCasil
                            • Oct 2013
                            • 23
                            Thanks for your input guys. I'll try to get it cleaned by tonight
                            -PCasil
                            IG: SJZOOSUAVEBOY
                            • PCasil
                              • Oct 2013
                              • 23
                              What do you guys think? Clean?
                              IG: SJZOOSUAVEBOY
