The 5 Year Restoration - E30 M3 Reborn
  • mwagner10702
    • Jun 2018
    • 49
    #691
    Originally posted by MyE30
    interested in how you obtained the headlamps
    See post #687
    1990 M3
    • CurrusDei
      • Mar 2014
      • 673
      #692
      Its taking forever, but it'll be worth the wait. They just cleared customs in Miami.
      _______________________________________________
      5 Year M3 Build, In Progress
      RMT200 Retrofit
      • MyE30
        • Sep 2013
        • 326
        #693
        definitely worth it for an e30m3. will be nice to see actual photos once you receive them.
        • CurrusDei
          • Mar 2014
          • 673
          #694
          Brief update, but more to come shortly. I'm going to finish this thing in short order. Motor start looks like this month, want it done by May beacuse 5 years is long enough
          Headlights arrived. Very much worth the wait.
          manual adjustment knob
          wires are inbound. have to re-wire to eurospec.
          New coolant cap
          Final hose - power steering pump to rack. The new versions are slimmer than the old
          Fitting shape is also different. I think this will still work, but we'll see
          I connected it up first, then had to undo it to fit in the steering u-joint. so, do the u-joint first, then the final line
          u-joint. top was easy to get on. the bottom wasnt. had to remove the bottom bolt (of course, wont go on with it on), line it up, and have my wife hammer on a bunch of socket extensions that were connected together and rested on the top of the lower section of the u-joint. it gradually went on, but was definitely a 2 man job to keep it aligned while hammering from the top.
          Got the throttle cables on
          Also, I had some degraded wiring connections. Found a good permanent fix...
          Coolant level sensor: Original wires in my hand, BMW replacements hooked onto the sensor
          Thermostat sensor connector: This one was a real beauty. Nice fix by the PO soldering rusted wires.
          Here's my fix. Of course you can just connect up the BMW replacement wires, but then you're left with just green wires and no way to tell which is which. My solution was to order the colored tabs in the picture below, along with clear heat shrink wrap.
          I cut sections of the color labels corresponding to the OEM wire color, wrapped them around the end of the wire, then used the clear heat shrink to encase it, so that whenever I need to know which wire is which, its right there
          Also, I switched to these instead of soldering or using crimp connectors. These things are awesome.
          Also, critically, Raychem DR-25 heat shrink wrapping is far and away the best I've found. It stays flexible after shrinking where many get stiff and brittle
          Coolant level sensor repair:
          Thermostat connector repair
          Other sensor
          T-stat in
          Also, I decided against the DSSR. Went with the factory one.
          First fitting had a lot of slack.
          Used more to close the gap per recommendations from other owners
          Brakes
          Disassembled the calipers. Messy job. had to use a grease gun to push the old pistons out.
          I tried cleaning them up a bit, but it wasnt happening. Sent them off to be zinc coated. I can not wait to get these back and on.
          RMT200 Retrofit
          • 0-60Motorsports
            • 65
            #695
            Another awesome update
            • Broken88
              • Jun 2017
              • 43
              #696
              Almost there! Love the picture-full updates!
              • iliad
                • 474
                #697
                Incredible work!
                Just read through the whole thread.
                Hope to see this beauty at The Vintage this year!
                • CurrusDei
                  • Mar 2014
                  • 673
                  #698
                  Originally posted by iliad
                  Incredible work!
                  ;D
                  I'm running full speed to finish her up. Been getting a lot of boxes lately. I spent my free time this weekend with degreaser and a pressure washer cleaning off the underside. Very dirty job, but i decided i couldnt leave the underside dirty when the rest of the car was so clean. I'm using an engine degreaser gel, and just got a short handle for my pressure washer. Thankfully temps this weekend will be warm so i can finish that part up and start the driveshaft/heat shielding work
                  Remaining to be installed
                  • Headlights (have)
                  • Brakes (in mail this week)
                  • Gauge restoration (going to Bavrest right after the motor starts up - hopefully this weekend if the brakes come in)
                  • Drive shaft (have)
                  • Front/Rear Glass (have)
                  • Heat shielding/underbody trim (have)
                  • Rear bumper trim behind wheels (in paint)
                  • Midsection (in mail)
                  • Evo 3 muffler (in mail)
                  • AC system (last parts arriving today)
                  • Bumper (complete, just need to mount)
                  • Evo Bumper and Hood seals (have)
                  • A few remaining factory decals (have)
                  • Spare wheel/tire (need)
                  • Dash/wiring (have, testing electrics before installing)
                  • M3 door seals (still off because of electrical testing)
                  • Door film (in mail - off for electrical testing)
                  • New Switches (in mail)
                  • E36 hand brake cover (in mail)
                  • Steering fluid (trans fluid, diff fluid, coolant are in)
                  • Badges
                  • A few other things im sure I'm forgetting
                  Will post update soon
                  RMT200 Retrofit
                  • AC_Schnitzel
                    • Sep 2017
                    • 149
                    #699
                    You’re a mad man... I’m so impressed by everything in this thread.
                    Have you ever restored a vehicle before? How are you confident that you’re not missing a step or doing something incorrectly?
                    I love the work you’re doing!
                    JP
                    WTB: Z3 1.9 lever, plastic bumpers, 19# injectors, Anthracite Cloth Sport Seats
                    Current
                    88 325 super eta
                    00 528i/5 (daily)
                    02 530iA sport
                    Former
                    04 525iA sport
                    87 325is
                    91 325i
                    97 528i
                    • CurrusDei
                      • Mar 2014
                      • 673
                      #700
                      Maybe
                      Thanks!
                      No, first time
                      Go slow, research what others have done, think through details, take 10,000 pics, know my limits, ask for input, fix something if I break it (no big issues yet - worst thing was stripping a thread for the rear ABS and having to re-tap)
                      Thanks!
                      Seriously it’s a function of time, thought, and teamwork. The guys at Korman have been invaluable, as was my body shop, as was my interior guy, as has R3V/S14/RealOEM/FCP/Bentley/old factory manuals and on and on
                      RMT200 Retrofit
                      • jhaurimn
                        • Nov 2012
                        • 2224
                        #701
                        I'm not on much anymore...but had to check in here to see how things were going.
                        Vintage eh? Maybe I'll see ya there. :)
                        Current:
                        1989 325i
                        1988 M3
                        1987 325ic
                        Past:
                        2001 330ci
                        2001 M3
                        • CurrusDei
                          • Mar 2014
                          • 673
                          #702
                          Lot going on. Working on the car whenever i have a free minute so no time to post updates. Pics will follow once i have the car off to the glass, exhaust, ac, other guys, but quickly:
                          Car is registered for the Vintage. It starts on my birthday this year, so that had to be my finish line.
                          All AC hardware installed (specialty shop will have to charge and make the connections at the compressor work, may require some hose customization). Everything is new except one line that was NLA, and I had it cleaned by a specialty AC shop
                          Dash in
                          Radio/controls in
                          All electricals work - everything. no shorts or other gremlins to chase
                          New signal stalk, refreshed cruise control and wiper stalk
                          New sunroof motor in (works)
                          Gauges restored by BavRest and installed
                          center console in
                          Shifter cover in
                          Door vapor barrier in
                          Door cards in
                          ///M Door sill covers in
                          B pillar covers in
                          engine wiring covers in
                          New fuse box cover in
                          Euro elipsoid smileys in with new euro connectors(4 bulb high beams function, city lights wired)
                          Front grilles (all 3) in
                          Front sway bar in
                          New Bosch battery with OEM vent in
                          New drive shaft center support bearing installed
                          New drive shaft guide bushing installed (this was a pain)
                          To do
                          Rear reflectors: should arrive tonight, putting in this evening hopefully
                          Rear sway bar: in this evening hopefully
                          Drive shaft: rear half is in. I bought the wrong size guibo, new one gets here tomorrow. Drive shaft should be done tomorrow night, then bolt up the front control arm lollipops and it should spend its first night on its own tires in about half a decade.
                          Glass: Have all the glass and found an expert shop to do it (they have done several E30 M3 restorations). The big glass guys all didn't want to touch it, and most hemmed and hawed about how the glass doesnt need to be glued in, they've done 5,000 of them so they know...blah blah. My only response was that there arent even 5k of these in the U.S. Anyways I'm hoping to get it to the glass shop late this week - open header, no windshield drive should be interesting
                          Underbody shields: I did some work with degreaser and a pressure sprayer to clean up the underside. Looking better. Will install heat shields tomorrow probably.
                          Hubs: Torque to spec when on ground, install lock nuts, center caps
                          Exhaust: Evo III muffler and VSR center in hand - going to have a really great welder put them on. I'll post some of his work once he confirms his availability, its weldporn level work. Contrast that to my old exhaust's welds, one of which has about a 1cm long stick weld section standing up out of it. Good metaphor for this whole process
                          Spare: Extra spare wheel should be here by tomorrow, getting it refurbished and putting on a new tire
                          Sunroof: waiting on two little rivets from Germany, then it will all go together. the rivets my upholstery shop used were too tall and wouldn't fit in the track. Putting the rivets in myself by hand, then it should all go together
                          Bumper: put it on
                          Body: Fine tune adjustment of hood/trunk/rear window to get even gaps. Install Evo hood gaskets
                          Ceramic/Film: Still considering here. There are some seriously talented ceramic coating and paint protection film guys in the area that I'm thinking about having do their "armored car" package on the car to protect it. Still undecided
                          My fingernails are pretty much always dirty these days. Also, fewer boxes of parts on the shelves. On the home stretch.
                          RMT200 Retrofit
                          • bradnic
                            • Jul 2012
                            • 3553
                            #703
                            Car is registered for the Vintage. It starts on my birthday this year, so that had to be my finish line..
                            That settles it. Picking up my airhead in Greenville and heading to Hot Springs!
                            HOWTOs:
                            DB vert plastic bumpers
                            OEM Keys
                            MTech1 docs
                            88 ix Lach/Card
                            91 ic Calypso 3.1
                            86 Cosmo 2.7
                            OEM+ or bust!
                            • AirDoc
                              • Sep 2006
                              • 29
                              #704
                              Awesome build...looking forward to seeing it at the Vintage!!
                              Nitin G. Shanbhag
                              BMWCCA #101510
                              76 2002, 88 M3 Racecar, 88 M3 2.5, 95 M3 Slicktop, 96 E36 Trackbeater , 97 M3/4 Slicktop
                              • CurrusDei
                                • Mar 2014
                                • 673
                                #705
                                Dropped her off to get glass (front/rear) today. Then its exhaust, then AC, then maybe ceramic/film
                                RMT200 Retrofit
