Opinions Needed: Which Shifter Rebuild Kit Should I Get?
  • CurrusDei
    • Mar 2014
    • 673
    Going to rebuild my shifter while I have the interior completely out.
    The shifter currently "buzzes" and wobbles back and forth (by itself) when driving. I'm pretty sure its not supposed to do that. I want to tighten it up, but dont care so much about shortening the throw. Definitely dont want to change height.
    Has anyone had good/bad experiences with a particular brand? I like the VAC one most right now.
    VAC "Better than New" Premium Kit - $190
    Turner sells the UUC Evo 3 Kit - $325 (+$125 if you add a DSSR, which I'm not sure how a big piece of metal like that wears out, but what do i know)
    http://www.turnermotorsport.com/p-35...es-e30-m3.aspx
    Bavauto has options ranging from $150-$500
    B&M has a kit - which im not considering because it doesnt have all the replacement bushings, etc.
    _______________________________________________
    5 Year M3 Build, In Progress
    RMT200 Retrofit
  • jhaurimn
    • Nov 2012
    • 2224
    This is the route I am going, wont be able to install until spring though.
    I am replacing #4 with this: http://store.garagistic.com/ocart/bm...hifter-bushing
    Along with 5, 6, 7, 10, and 11. #4 is where most of the slop comes from, so the upgrade to the delrin bushings is generally considered a worthwhile upgrade. I will probably replace my transmission mounts at the same time too.
    Current:
    1989 325i
    1988 M3
    1987 325ic
    Past:
    2001 330ci
    2001 M3
    • markseven
      • Sep 2006
      • 5327
      IMO the stock lever is best. Not only do the various SSKs reduce leverage, but they are sometimes notchy. YMMV.
      I find that BMW absolutely nailed the driver interface on the E30s. The shifter length, height of the knob (people are making the tall knobs like the OE M3 unit now), pedal placement / spacing, and steering wheel position (even without adjustments), is perfect.
      If I were you I would get OE replacements for the wear items and spend the leftover cash on a DSSR from AKG or UUC, which is one of the best upgrades around.
      I Timothy 2:1-2
      • markseven
        • Sep 2006
        • 5327
        Just saw your note about the shift rod. Double-shear is a robust attachment method, far superior to the OE single shear, which contributes to early wear of the washers, where the play / slop comes from.
        I Timothy 2:1-2
        • dude8383
          • Jan 2005
          • 10387
          I recommend what the poster above did. Its less expensive but pretty much does the same thing. You just need to figure out which lever you want to go with.
          • CurrusDei
            • Mar 2014
            • 673
            ahh, that helps. Yeh i have no desire to replace more than i need to. upgraded bushings and selector rod sounds like a good option. I agree about BMW nailing the driver interface on this car - plus the object of my restoration is to stay very close to the original with reliability/other improvements where these dont interfere with the OEM feel.
            RMT200 Retrofit
            • rturbo 930
              • Dec 2005
              • 2629
              This was my experience with a UUC SSK. Not only that, I feel like the install method, and the lever itself is way too complicated and overly engineered. The price doesn't help, either. I took it out after maybe 1k miles, and put the stock lever back in with the DSSR and it is so much nicer. At some point, I'd like to get a Z3 1.9 shift lever.
              So, that would be my recommendation - Z3 1.9 lever, DSSR, and upgrade the various bushings. Also make sure you replace #16 in the diagram posted above, I feel like people overlook that one.
              • CurrusDei
                • Mar 2014
                • 673
                What are people's thoughts on the delrin rear bushing? I see in one of the reviews someone saying it would cause problems if you have stock transmission mounts (which i plan to keep).
                Anyone replace this piece? #13
                Also, why are some of you recommending replacements for metal hardware? Doesn't look like these would wear out. I'm open to suggestions though
                #5 - pin
                #6 - self locking collar nut
                RMT200 Retrofit
                • nauqneyugn
                  • Oct 2012
                  • 201
                  When I rebuilt mine, I felt like the delrin version of #4, #13 (or you can just replace the little sponge inside it #16) and a DSSR made the most difference. I replaced #7 because mine was destroyed and #2 because the holes which #5 inserted through were ovalized.
                  • jhaurimn
                    • Nov 2012
                    • 2224
                    If you replace 7, there's no need for a rear Delrin bushing.
                    I'm replacing 5 or 6 for the sake of new hardware :)
                    And yeah, the reason I opted out of the dssr is I didn't want it overly notchy
                    Current:
                    1989 325i
                    1988 M3
                    1987 325ic
                    Past:
                    2001 330ci
                    2001 M3
                    • mitchlikesbikes
                      • Dec 2013
                      • 858
                      DSSR doesn't make the shifter feel notchy at all. unless you consider anything tighter than peanut butter gears "notchy"
                      here is my setup, it feels great. nice and crisp, but not notchy at all, ever. you could just use the stock shift lever too if you want to keep the same height on the setup.
                      UUC DSSR
                      garagistic carrier bushing (only the front one, #4 in the diagram)
                      new oem ball cup bushing and yellow washers for the DSSR
                      custom nylon bushing on the trans input fitting (#13 in the diagram)
                      custom delrin knob
                      there are some pictures of the height and what not in my build thread too
                      at the very minimum replace all the bushings with oem and get a DSSR. it really does make the shifter feel so much better.
                      IG: @mitchlikesbikes
                      • markseven
                        • Sep 2006
                        • 5327
                        Yep. The other aftermarket part I like is RSMs. I have Rogue units sitting on a shelf waiting to go on the car.
                        I Timothy 2:1-2
                        • CurrusDei
                          • Mar 2014
                          • 673
                          Got those about a month after I got the car. The old ones were toast. Added new stock shocks as well
                          RMT200 Retrofit
                          • markseven
                            • Sep 2006
                            • 5327
                            +1 on this. The DSSR does not alter the stock geometry.
                            I Timothy 2:1-2
                            • dude8383
                              • Jan 2005
                              • 10387
                              The DSSR makes a huge improvement. Decreases shifter play and shift effort because its a nice weighted piece. I love mine.
