Off center front wheel
  • D-rock
    • 714
    Hey guys I really need help on this.
    I purchased this car with the five log swap already installed.
    One year later I did a suspension over haul. I changed the suspension all the links control arms and what not, but now the wheel has seemed to be pushed back from where it was originally.
    Maybe the pervious owner used an e46 control arm?
    What I used.
    e30 to e36 ground control suspension
    e36 M3 96+ Arms
    Off set arm bushing
    Everything was purchased from Turner Motorsports so I doubt they sold me the wrong item.
    Any help would really be great! Thanks in advance!
    Here is a photo of how the wheel sits and the second photo is of the original control arm that came with the car.
  • Cabriolet
    • 9620
    did you flip the new bushing around the wrong way?
    Much wow
    I hate 4 doors
    • D-rock
      • 714
      I don't think so I even had a shop check it out while doing some other work and it looked fine.
      • D-rock
        • 714
        Any other suggestions?
        • DTMbimmer07
          • 1485
          did u buy this car from eral or jackie?
          • D-rock
            • 714
            Yeah his name was Eral! Why?
            • DTMbimmer07
              • 1485
              there 318ti control arms u need to get 96+ E36 M3 control arms. let me know if you have any other questions.
              • DTMbimmer07
                • 1485
                just reread the thread. so u changed the control arms to m3 ones now? i know originally he had the 318ti controls on there and he bent them to make them fit where he wanted them too.
                • einstein57
                  • Jun 2007
                  • 10780
                  Wow thats sketch. I'd look in to getting the 96+ fronts spindles and brakes. That should get you a lot closer to center.
                  www.gecoils.com
                  • D-rock
                    • 714
                    Thanks for the reply! They don't look bent from the picture I attached or do they? I originally used e30 ones then I swapped them out to e36 m3 arms and I didn't see very much of a difference.
                    Is there a way to know if I already have these or not? I would hate to replace all this and be in the same place :/
                    Thanks
                    • Blackout
                      • Apr 2011
                      • 4130
                      Thanks
                      96+ M3 knuckles have 907/908 Left and Right respectively stamped on the back. Check it. If it is anything else, its non-M.
                      » PARTS FOR SALE
                      » TRANSACTION FEEDBACK
                      • einstein57
                        • Jun 2007
                        • 10780
                        They also have ///M on the front of the brake calipers.
                        www.gecoils.com
                        • D-rock
                          • 714
                          I know for a fact that my calipers are not e36 M3, but is there still a chance I could have e36 m3 spindles? Will changing only the spindles to M move the tire that far forward?
                          • Blackout
                            • Apr 2011
                            • 4130
                            Your control arms are the problem. They are not 96-99 M3 part.
                            Also check check at the back of the spindle, like i said.
                            What numbers are on your control arms? Are they OEM?
                            Which offset bushings are you using?
                            Left is E36 M3. Right is E36.
                            » PARTS FOR SALE
                            • D-rock
                              • 714
                              They are OEM control arms but I do not remember seeing any numbers on them. I will check on that and the spindles in the morning. I doubt the spindles are M3 but I paid $200 a piece for the control arms I hope I didnt get screwed.
                              I am using these bushings
                              http://www.turnermotorsport.com/p-36...30-e36-z3.aspx
                              Thanks again!
