Subaru Hubs = E30 hubs?
  • F34R
    sLaughter
    • 12376
    In for results! I would love to rock some old school SSR or something Jap as fuck. Only issue would be finding a front bearing that would match the rear pattern.
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • LJ851
      • 7919
      I want some macho sauce! Sounds good.
      OP, which E30 hub are comparing to the subaru hub? The only 57.1 dimension on the rear hub (which is splined like you mention) is wheel locating diameter. The ID is splined and the OD is like 42mm.
      The front hub has no splines and i cant recall the ID that the bearing fits into cause you pretty much have to buy the hub and bearings together complete.
      Lorin
      The M30 is God's engine.
      • ForcedFirebird
        • Feb 2007
        • 8300
        Originally posted by Bimmerman325i
        5x114.3 is going to be a problem unless you like JDM wheels.
        5x114.3 is the same as 5x4.5". American car size.
        john@m20guru.com
        Links:
        • 1craze30
          • 1224
          Any news on this? If the SVX hub fits, the the cheaper option would be to use an earlier model hub from an XT6. The XT6 is the prequel to the SVX and share the same suspension components like hubs, struts, springs, axles. I sure if this does in fact fit, the XT6 would be a cheaper option.
          • Crodell6
            • May 2011
            • 142
            I was referring to the rear hub if i managed to get it to work I'd move on to the front. The ID of the svx and e30 both share 42.
            The OD of the bearing On the other hand is 75(e30), 72(svx). So the bearing Ultimately wouldn't fit.
            I'm not stopping though. I'll digg around some more and see if there's a match!
            • Crodell6
              • May 2011
              • 142
              Once i get the hub and a new e30 bearing here then I'll look over the depth of each hub and report back.
              • Roysneon
                • 4505
                PM Blunt.
                Originally posted by P.Kelly
                Or, since s/he has 3 posts and no track record, s/he could actually have been serious and enthusiastic.
                Is this you?
                Originally posted by mbonanni
                I am a pursit now.
                • Crodell6
                  • May 2011
                  • 142
                  Still waiting for the hubs...
                  Called in to a dismantler in New York on Thursday. Said they would call when the part was pulled, no call back yet.
                  • owwwch
                    • Dec 2012
                    • 24
                    i wonder if the fronts would work on an ix?
                    • TobyB
                      • 5288
                      no call back yet.
                      man, he left you hangin'....
                      t
