M3 hubs
    M3 hubs
    Thought I'd show what I've been doing to the e30.
    Just to clarify those are regular e30 struts.
    do tell more...
    Nitin G. Shanbhag
    BMWCCA #101510
    76 2002, 88 M3 Racecar, 88 M3 2.5, 95 M3 Slicktop, 96 E36 Trackbeater , 97 M3/4 Slicktop
      more curious about the rear
      1991 325iS turbo
        Not done yet with rear. Needs more machining.
          E30 m3 rear hubs are direct replacement for non M and are available. The rear caliper brackets/carriers on the other hand...
          Originally posted by mbonanni
          I am a pursit now.
            If you are a member of s14.net you can find them pretty easily. I got a set with rotors and pads in about 2hrs.
            I'm going to see how the calipers fits on a stock e30 rear end while i'm doing to swap just to see what the offset is like. I'm not expecting much, but that'd be an easy brake upgrade, although probably a waste of money.
            1986 911 Supercharged Frakenstrat/Stripped
            1987 325is Delphin/Black (Olga)
            1988 M3 Zinno/Natur (Elsa)
            Manual or STFU
            E30 Chapter of BMW Car Club of America
            E30 Oktoberfest 2017
              Any updates to this?
              09 BMW 328xi touring 6spd
              05 Subaru Outback XT 5spd
              87 BMW 325is
              a few bicycles
                So I got it all finished up and have a 2000 miles on the setup with no issues thus far.
                Here is a few pics of how the rear works. I machined a 1/2" plate to fit over the existing hub making it thicker and larger around. welded it all up with 308L rod and machined it flat and drilled the bolt pattern. Kinda skipped some steps in the photos but I was anxious to get it together.
                  The front uses a stock e30 4 lug strut and adds a sleeve to fit the e28/e30 m3 Bearing. This puts the front at the stock offset as the e30 but I used rx7 brakes so spacers are required anyway.
                    Interesting
                    87 BMW 325is
                    a few bicycles
                      Yes its different.
                        I like the fact that you seemed to have pulled this off. Very cool! Any idea if you'll produce or modify this for others?
                        87 BMW 325is
                        a few bicycles
                          I can post the measurements to have the spacer made. The rears are very time intensive. Probably 8 hrs of welding and machining spread over several weeks. (Lots of tig welding) So thy would be cost prohibitive to sell.
                            I'd like to see that please. I have access to a machine shop and have a friend that tig welds so this might be a possibility. Thanks
                            87 BMW 325is
                            a few bicycles
                              What do you use as rotors?
                              Manual or STFU
