e46 front strut/arm/knuckle setup
    has anyone tried fitting an entire front corner from a e46M onto an e30?
    I know the front Aluminum A arms are done by some (and akg sells adaptive bushings for them)
    but if the arm bolts on; the E46 tie rod end can be bolted to whatever rack desired
    (our race E30 has a e46/z4 rack currently with e36 tie rod end to use with e30 strut and hub)
    IF the Tie rod end/ steering rack is e46, the e46 hub will mate with it properly
    if the e46 aluminum lower A arm is used then a e46 knuckle will also fit perfectly (although might be in very wrong place for an e30)
    a E46 front coilover setup is easily adapted to e30 top hat with a phone call to ground control.
    just wondering if this idear of frankensteining has been tried (and if it will do similar to the e36m 5 lug effect)
    the e46 has the shock slip fit into the knuckle; its more similar to an e30 setup in mechanism than a e36 is (IMO)
    I'm sure you're onto something. I run the none-M e46 arms with SLR adjustable CABs on my e30. I think the only think you need to keep in mine is how wide your track will be. The none-M are a good inch further than the e36m, and the e46m push even more.
    I have seen a comparison pictures floating around, I tried finding it but no luck. I do Like your idea though, no super bulky e36m knuckle, better brake options.
    Instagram @rebellionforge
      Thinking there was an Australian or a South African that weld in both front and rears. Think it was on Bimmerfest.com
        He did the rear like that. e46 should all bolt right up in front, just have to deal with wide track width and excessive camber created by it.
          The suspension geometry will be all messed up like it is when doing E36 suspension swaps. It would be even more difficult to get proper geometry than the E36 because you could not easily make a new strut tube at a different angle since it slips in and is not bolted on.
          -Nick
          M42 on VEMS
            There are 2 versions at least of e46 non m arms then there are e46m arms also.
            Between those its quite possible to have a better 5 lug /brake solution than the current e36m3 partsbit setup from a 96-98.
            Why spend premium on weird low run production high cost and heavy arms when e46 aluminum arms new are dime a dozen new aftermarket?
            Im just talking math for consumption (wheel 2 wheel racing needs lots of spares)
              I have the Meyle HD arms on mine. You need adjustable Lcabs like you stated to correct the caster, other than that it should be fine.
                need to revive this again , any updates on this ?
                  The e46m lower control arms are designed to work with the aluminum brace under the engine. The ball joints bolt through it. Not a bad thing but something additional to deal with. The z4m may be a better choice as they use sport package non m e46 control arms and offset bushings like the e30m & early e36m.
                    How close are the E46M arms to E36 96+ geometry? Yes, extra Camber, But what about that caster?
                    Zach@Zakspeed.us
