Gemballa E30 Suspension Help
  • GemballaE30
    • Feb 2022
    • 3
    Hey everyone, I recently picked up a Gemblla E30 and I am trying to fix some of the minor issues that it has. Currently it has some fitment issues, and it rubs pretty bad at full lock and if I have any real weight in the back seats. I am looking for the best way to fix some of the wheel tuck, and rubbing issues. I am thinking a little stiffer springs and spacers, but I have no clue where to even start. I don't know what is on the car either to go from, I am planning on getting a lift to get it in the air so I can get some better info to give.
  • moatilliatta
    • 6150
    Are the springs broken? Does it have different wheels then the original Gemballa ones?
    Assume any car with wide wheels, wide fenders, lowered will benefit from steering rack stops.
    @Zakspeed_US
    • GemballaE30
      • Feb 2022
      • 3
      Honestly, I don't know what the original Gemballa wheels are. I am trying to get in contact with Gemballa to see if they have an original spec sheet for it. But the springs seem like they may be worn out, but I am not sure however. I am getting it on a lift this weekend to take a good look at the car. Currently it has some 80's looking Panasports on it, the front is running 225/50/15 on 4x100, the rears are 265/50/15 on 4x100. The rear has a pretty deep offset as well. I also didn't think of steering rack stops, that's a smart suggestion. But with the rear rubbing, even 150lbs in the backseat makes it rub pretty regularly if the front seats are being used. I am worried about doing damage to the body kit or blowing a tire if I keep it how it is set now.
      • 95BMWIC
        • Apr 2012
        • 353
        You bought this? https://www.conceptcarz.com/z29863/gemballa-e30.aspx
        This particular example is a BMW E30 Gemballa powered by a 2.5-liter six-cylinder engine mated to a five-speed manual transmission. It was built in Leonberg, Germany and is possibly the only E30 BMW in the United States.
        More here:
        Crazy... Nice.. Looks like custom wheels..
        Did you buy it from this guy?
        Or is there another one that made it to US? If so post some pics..
