what do i need for new susp install?
  • robert325is
    • Aug 2004
    • 1171
    I'm planning to install a Koni SA/IE Stage 3 Race Springs Combo. I was just wondering what all I needed to get in the way of replacing mounts and whatnot.
  • Erick
    Official R3V Drifter
    • 11169
    Good combo.
    You dont HAVE to replace anything, however assuming nothing was ever replaced, it'd be a good idea to do so right now. Rear shock mounts, Upper strut mounts, etc.....
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
    • kencopperwheat
      King of Kegstands
      • 14396
      Yeah, get new rear shock mounts and strut bearings. Also get new front and rear swaybar links.
      Originally posted by Gruelius
      • hamann318is
        • 3382
        Bare minimum would be the Rear Shock Mounts and the Front Strut Bearings. I also did tie rods, control arms, control arm bushings, and sway links, but I'm obcessive. ;)
        Look at the kit from Turner, they have all the screws, so you don't have to reuse the self-locking ones on the car currently.
        The BMW 318 is back. With a vengeance.
        • Digitalwave
          is a poseur
          • 6302
          I'd also recommend replacing all the locking nut hardware that you remove. Its cheap and a good safety measure.
          RISING EDGE
          • robert325is
            • Aug 2004
            • 1171
            link?
            • Jon325i
              • 6934
              Re: what do i need for new susp install?
              That set up you're about to install is something I'm considering when I have to re-vamp my suspension. I just e-mailed Jeff Ireland the other day and threw a few questions at him about the stage 3 springs. They sound like good street/track components.
              As for the parts you need: definately get RSMs (at least E46 grade or aftermarket), strut bearings and hardware like the bits TJ mentioned. You will have everything apart....so why cut corners?
              Have you thought about getting fixed or adjustable camber plates? Now would be the time to do it.
              Jon
              Rides...
              1991 325i - sold :(
              2004 2WD Frontier King Cab
              RIP #17 Jules Bianchi
              • robert325is
                • Aug 2004
                • 1171
                Jon
                yah i have... im no sure what would be better to go with though.. i do mostly daily driving and dont plan on having much track time
                • cthulu703
                  • Oct 2004
                  • 288
                  Remember that nylock nuts are single use only. You should have those on hand. I just did my suspension this weekend, and for all the hardware it was about $40 as the stealership.
