ABS wire connector - Body side
  • racingwoody
    • Jun 2006
    • 438
    Does anyone know where I can purchase the body side ABS connector to splice back into the harness. I have new ABS speed sensors, and the connectors fell apart in my hand when unplugging the old.
    Thanks,
    Kevin Gibson
    90 325is
  • racingwoody
    • Jun 2006
    • 438
    So I found PN 61131390540 - Does anyone know if this is the entire bodyside harness with 4 male connectors?
    Kevin Gibson
    90 325is
    • Vincenze
      • Apr 2019
      • 1034
      61131390540 is 1 connector plus wire.
      You can search for connectors on eBay, but they will be old too.
      It's time to create a 3D model of the connector cut in half and print it.
      • racingwoody
        • Jun 2006
        • 438
        Yea, my wires are in great shape, just need to the connector. Thanks for the help. Costly repair. WOW.
        Kevin Gibson
        90 325is
        • 82eye
          • Jan 2009
          • 2094
          same thing on mine. i'll probably just do an abs delete sometime. they get unreliable with age, and in emergency braking the e30 abs really just activates to let you know it's too late anyway.
          • racingwoody
            • Jun 2006
            • 438
            If I find some used ones in a junk yard can they be spliced into the harness or do they have any special resistor or wire capacity that splicing could effect the signal?
            Kevin Gibson
            90 325is
            • 82eye
              • Jan 2009
              • 2094
              mine deteriorated enough that they also fell apart at the clip on the strut. if it was just the underhood connector i would try it.
